HP Color LaserJet CM6040 Colour Laser Multifunction Printer
HP Color LaserJet CM6040 MFP
Quicklinx: 54LRWS00 Mfr#: Q3938A#B19
See productivity soar with this high performing Color LaserJet MFP. Create A3 colour documents with excellent line and image quality. Enjoy fast print speeds; print, copy, scan, fax and digital sending functionality plus exceptional ease of use.
HP Color LaserJet CM6040 MFP - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
220000 impressions
Recommended Monthly Volume
8000 - 15000 pages
Max Copying Speed
Up to 40 ppm (mono) / up to 40 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 41 ppm (mono) / up to 41 ppm (colour)
Max Printing Resolution
Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
Scanning
600 dpi
Original Size
A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
1100 sheets
Max Media Capacity
1100 sheets
Output Trays Capacity
500 sheets
Stacker
Optional
Stapler
Optional
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Security lock slot
70.4 cm x 63.5 cm x 119.4 cm
139.9 kg
Microsoft Certification
Certified for Windows Vista
Environmental Standards
EPEAT Bronze, ENERGY STAR Qualified
Printing Technology
Laser - colour
220000 impressions
8000 - 15000 pages
Security lock slot
Standard Memory
512 MB 512 MB
Max Supported Memory
1 GB 1 GB
Hard Disk Drive
80 GB
Copying
Max Copying Speed
Max Document Enlargement
200%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Scanning
Optical Resolution
600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
1100 sheets
Max Media Capacity
1100 sheets
500 sheets
ADF - 50 sheets , 2 x input tray - 500 sheets , Input tray - 100 sheets
Finishing Equipment
Stacker
Optional
Stapler
Optional
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, Apple Mac OS X 10.3, Apple Mac OS X 10.2.8, Apple MacOS X 10.4 or later, MS Windows Vista
920 Watt
Power Consumption Standby
230 Watt
Power Consumption Sleep
24.5 Watt
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Security Slot Type
Kensington security slot
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
70.4 cm
63.5 cm
119.4 cm
139.9 kg
Shipping Weight
154.9 kg
15 °C
27 °C
Resources
The following resources are available for the HP Color LaserJet CM6040 Colour Laser Multifunction Printer
