Get advanced print, copy, fax, and scan capabilities in a single easy-to-use device, eliminating the expense and space of multiple single-function devices. Receive both black-and-white and color output quickly with print speeds of up to 21 pages per minute (ppm) on letter-size paper.Typical office print job Time To Completion can be nearly three times faster with the MFP's Instant-on Technology. Instant-on Copy with LED-based scanning technology delivers your first copy in seconds.With a total input capacity of up to 550 sheets, you can stay focused on your work. Use the 50-page automatic document feeder (ADF) for unattended copying, scanning, and faxing. Save time with built-in automatic two-sided printing and copying.The HP Color LaserJet CM2320fxi MFP's photo memory card slots make it simple to create impressive marketing materials with high-quality photo accents. Import images directly into business documents, or print them from the control panel.Print professional-quality brochures and more at your desk. Free HP marketing tools allow you to create and customize your documents instantly, so each communication speaks directly to your customers' needs. With the included Print View feature, you can change print settings and see immediately how those changes affect your document before you print. Determine costs beforehand for better project planning and decision-making with the Print Cost Estimator.Easily get optimized print quality for each of the many supported media types. With a single click in your print driver, select from a collection of pre-configured Printing Shortcuts - including settings for everyday printing, envelopes, glossy paper, and more.This MFP is not just easy to use - it's also easy to install, share, and maintain. Set-up wizards and installers help you get started. Original HP print cartridges are preinstalled and a handy front-access panel makes replacement effortless.Ideal for small work teams, the MFP offers networking performance. Manage your MFP with HP Easy Printer Care Software, a simple tool to deploy, monitor, and maintain up to 20 devices.
Enhances productivity
Get advanced print, copy, fax, and scan capabilities in a single easy-to-use device, eliminating the expense and space of multiple single-function devices. Receive both black-and-white and color output quickly with print speeds of up to 21 pages per minute (ppm) on letter-size paper. Typical office print job Time To Completion can be nearly three times faster with the MFP's Instant-on Technology. Instant-on Copy with LED-based scanning technology delivers your first copy in seconds. With a total input capacity of up to 550 sheets, you can stay focused on your work. Use the 50-page automatic document feeder (ADF) for unattended copying, scanning, and faxing. Save time with built-in automatic two-sided printing and copying. The HP Color LaserJet CM2320fxi MFP's photo memory card slots make it simple to create impressive marketing materials with high-quality photo accents. Import images directly into business documents, or print them from the control panel. -
Unlimited possibilities
Print professional-quality brochures and more at your desk. Free HP marketing tools allow you to create and customize your documents instantly, so each communication speaks directly to your customers' needs. With the included Print View feature, you can change print settings and see immediately how those changes affect your document before you print. Determine costs beforehand for better project planning and decision-making with the Print Cost Estimator. Easily get optimized print quality for each of the many supported media types. With a single click in your print driver, select from a collection of pre-configured Printing Shortcuts - including settings for everyday printing, envelopes, glossy paper, and more. -
Simplifies your office
- HP Color LaserJet CM2320fxi - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English / United Kingdom
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 impressions
- Recommended Monthly Volume
- 1000 - 2500 pages
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Media Type
- Transparencies, envelopes, plain paper, cards, labels
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 550 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, LAN
- 49.7 cm x 49.2 cm x 65 cm
- 32.3 kg
- Microsoft Certification
- Works with Windows Vista
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 40000 impressions
- 1000 - 2500 pages
- Interface
- USB 2.0, LAN
- Localisation
- Standard Memory
- 160 MB 160 MB
- Max Supported Memory
- 1 GB 1 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
Scanning
- Optical Resolution
- 1200 dpi
- Interpolated Resolution
- 19200 dpi
- Grayscale Depth
- 8-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
Fax Machine Features
- Broadcast Transmission
- 119 stations
- Fax forwarding, automatic redialing, dual-line fax capability, junk fax barrier
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- 550 sheets
- 550 sheets
- 150 sheets
- ADF - 50 sheets , 2 x input tray - 250 sheets , Input tray - 50 sheets
- 1 x USB 2.0 , 1 x LAN
- Operating System Support
- MS Windows 2000, Novell NetWare 6, Novell NetWare 5.x, Novell NetWare 4.x, HP-UX 10.2, Novell NetWare 3.x, MS Windows Server 2003, MS Windows XP Media Center Edition, Apple MacOS X 10.3 or later, MS Windows XP Tablet PC Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows XP Home Edition, MS Windows XP Professional
- 460 Watt
- Power Consumption Standby
- 27 Watt
- Power Consumption Sleep
- 9.2 Watt
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year - on-site - response time: next business day
- 49.7 cm
- 49.2 cm
- 65 cm
- 32.3 kg
- Shipping Width
- 80 cm
- Shipping Depth
- 65.3 cm
- Shipping Height
- 60 cm
- Shipping Weight
- 52.2 kg
- 15 °C
- 30 °C
- 10 - 80%
