HP Color LaserJet CM2320fxi - ( fax / copier / printer / scanner )
HP Color LaserJet CM2320 Multifunction Printer
Quicklinx: 5745WS00 Mfr#: CC435A#ABU
Get advanced print, copy, fax, and scan capabilities in a single easy-to-use device, eliminating the expense and space of multiple single-function devices. Receive both black-and-white and color output quickly with print speeds of up to 21 pages per minute (ppm) on letter-size paper.Typical office print job Time To Completion can be nearly three times faster with the MFP's Instant-on Technology. Instant-on Copy with LED-based scanning technology delivers your first copy in seconds.With a total input capacity of up to 550 sheets, you can stay focused on your work. Use the 50-page automatic document feeder (ADF) for unattended copying, scanning, and faxing. Save time with built-in automatic two-sided printing and copying.The HP Color LaserJet CM2320fxi MFP's photo memory card slots make it simple to create impressive marketing materials with high-quality photo accents. Import images directly into business documents, or print them from the control panel.Print professional-quality brochures and more at your desk. Free HP marketing tools allow you to create and customize your documents instantly, so each communication speaks directly to your customers' needs. With the included Print View feature, you can change print settings and see immediately how those changes affect your document before you print. Determine costs beforehand for better project planning and decision-making with the Print Cost Estimator.Easily get optimized print quality for each of the many supported media types. With a single click in your print driver, select from a collection of pre-configured Printing Shortcuts - including settings for everyday printing, envelopes, glossy paper, and more.This MFP is not just easy to use - it's also easy to install, share, and maintain. Set-up wizards and installers help you get started. Original HP print cartridges are preinstalled and a handy front-access panel makes replacement effortless.Ideal for small work teams, the MFP offers networking performance. Manage your MFP with HP Easy Printer Care Software, a simple tool to deploy, monitor, and maintain up to 20 devices.
  • Enhances productivity
    Get advanced print, copy, fax, and scan capabilities in a single easy-to-use device, eliminating the expense and space of multiple single-function devices. Receive both black-and-white and color output quickly with print speeds of up to 21 pages per minute (ppm) on letter-size paper. Typical office print job Time To Completion can be nearly three times faster with the MFP's Instant-on Technology. Instant-on Copy with LED-based scanning technology delivers your first copy in seconds. With a total input capacity of up to 550 sheets, you can stay focused on your work. Use the 50-page automatic document feeder (ADF) for unattended copying, scanning, and faxing. Save time with built-in automatic two-sided printing and copying. The HP Color LaserJet CM2320fxi MFP's photo memory card slots make it simple to create impressive marketing materials with high-quality photo accents. Import images directly into business documents, or print them from the control panel.
  • Unlimited possibilities
    Print professional-quality brochures and more at your desk. Free HP marketing tools allow you to create and customize your documents instantly, so each communication speaks directly to your customers' needs. With the included Print View feature, you can change print settings and see immediately how those changes affect your document before you print. Determine costs beforehand for better project planning and decision-making with the Print Cost Estimator. Easily get optimized print quality for each of the many supported media types. With a single click in your print driver, select from a collection of pre-configured Printing Shortcuts - including settings for everyday printing, envelopes, glossy paper, and more.
  • Simplifies your office
HP Color LaserJet CM2320fxi - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
English / United Kingdom
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
40000 impressions
Recommended Monthly Volume
1000 - 2500 pages
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
Scanning
1200 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Media Type
Transparencies, envelopes, plain paper, cards, labels
Standard Media Capacity
550 sheets
Max Media Capacity
550 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, LAN
49.7 cm x 49.2 cm x 65 cm
32.3 kg
Microsoft Certification
Works with Windows Vista
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Laser - colour
40000 impressions
1000 - 2500 pages
USB 2.0, LAN
Standard Memory
160 MB 160 MB
Max Supported Memory
1 GB 1 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Scanning
Optical Resolution
1200 dpi
Interpolated Resolution
19200 dpi
Grayscale Depth
8-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Machine Features
Broadcast Transmission
119 stations
Fax forwarding, automatic redialing, dual-line fax capability, junk fax barrier
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
550 sheets
Max Media Capacity
550 sheets
150 sheets
ADF - 50 sheets , 2 x input tray - 250 sheets , Input tray - 50 sheets
1 x USB 2.0 , 1 x LAN
Operating System Support
MS Windows 2000, Novell NetWare 6, Novell NetWare 5.x, Novell NetWare 4.x, HP-UX 10.2, Novell NetWare 3.x, MS Windows Server 2003, MS Windows XP Media Center Edition, Apple MacOS X 10.3 or later, MS Windows XP Tablet PC Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows XP Home Edition, MS Windows XP Professional
460 Watt
Power Consumption Standby
27 Watt
Power Consumption Sleep
9.2 Watt
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
ENERGY STAR Certified
Limited warranty - parts and labour - 1 year - on-site - response time: next business day
49.7 cm
49.2 cm
65 cm
32.3 kg
Shipping Width
80 cm
Shipping Depth
65.3 cm
Shipping Height
60 cm
Shipping Weight
52.2 kg
15 °C
30 °C
10 - 80%
