Get productive MFP performance – world's smallest colour laser in it's class. Print, scan, and copy, produce high-quality colour results, and print and scan from your phone.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Uncompromising laser quality
This surprisingly small laser delivers exceptional quality, page after page. -
Sharp black text, high-quality colour
Produce sharp text, bold blacks, and crisp colour graphics. -
The right price
Rely on a high-performance laser printer at an affordable price. -
The power of your printer in the palm of your hand
Get simple setup, and print and scan from your phone, with the HP Smart app. -
Your device, your choice
Easily print from a variety of smartphones and tablets. -
Extend your printing reach
Easily share resources – access and print with wireless and Ethernet networking.
- HP Color Laser MFP 178nw - multifunction printer - colour
- Multifunction printer
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 100 - 500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 4 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 40 sheets
- Media Size
- 76 x 148.5 mm (min) - 216 x 356 mm (max)
- Media Type
- Labels, recycled paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy paper, preprinted paper, coloured paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 50 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Office Machine Features
- Wireless direct printing, AirPrint ready, Mopria certified, Mobile Printing, scan to PC, Google Cloud Print
- Power
- AC 230 V (50/60Hz)
- 40.6 cm x 36.3 cm x 28.87 cm
- 12.94 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Laser - colour
- 20000 pages
- 100 - 500 pages
- Display
- 2 lines
- Display Features
- LCD display
- Interface
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
Printing
- First Print Out Time B/W
- 12.4 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 10-bit
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- 40 sheets
- Min Media Size
- 76 x 148.5 mm
- Max Media Size
- A4/Letter
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm), 216 x 356 mm
- 150 sheets
- 50 sheets
- ADF - 40 sheets - A4 (210 x 297 mm) , Input tray - 150 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Output tray - 50 sheets
- Speed Details
- Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 4 ppm (A4) - colour (ISO) , Copying: up to 18 ppm (A4) - B/W normal , Copying: up to 4 ppm (A4) - colour normal
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN
- Voltage Required
- 300 Watt
- Power Consumption Standby
- 38 Watt
- Power Consumption Sleep
- 1.9 Watt
- First Copy Out Time B/W
- 12.6 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 700 pages , 1 x toner cartridge (magenta) - up to 700 pages , 1 x toner cartridge (yellow) - up to 700 pages
- DEMKO, FIMKO, GS, NEMKO, SEMKO, ANSI C63.4-2009, CECP, IPv6 Ready, EN 62479:2010, CNS 13438, Blue Angel Ecolabel, EN 61000-3-3:2013, EN 55024:2010, CISPR 22:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 5, KN32, KN35, EN 55032:2012, IEC/EN 60825-1:2014 Class 1, CISPR 32:2012, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 40.6 cm
- 36.3 cm
- 28.87 cm
- 12.94 kg
- Shipping Width
- 50.1 cm
- Shipping Depth
- 46.6 cm
- Shipping Height
- 39.8 cm
- Shipping Weight
- 16.08 kg
- 15 °C
- 27 °C
- 10 - 80% (non-condensing)
HP 117A Black Original Laser Toner Cartridge | In Stock | £34.93 |
HP 117A Cyan Original Toner Cartridge | In Stock | £38.71 |
HP 117A Yellow Original Toner Cartridge | In Stock | £38.71 |
HP 117A Magenta Original Toner Cartridge | In Stock | £38.71 |
HP 120A Original Laser Imaging Drum | In Stock | £84.37 |
HP Glossy Laser Paper 150GSM 150 SHT/A4 | In Stock | £14.44 |
