Super-fast and incredibly intuitive, the Chromebook x360 helps you make the most of the entire Google ecosystem, putting millions of apps right at your fingertips. With a modern look and feel, plus four unique modes, this slim PC is designed for everything you do, and so much more.
Chrome
This easy-to-use operating system was designed to be fast in every possible way, while keeping you safe and more secure on the web. -
Dual-core Intel Pentium processor
The perfect combination of performance, power consumption, and value helps your device run smoothly and reliably with two processing cores to handle all your tasks. -
FHD IPS touchscreen
Always see your content at its best with 178° wide-viewing angles and a vibrant picture. And with touchscreen technology, you can control your PC right from the screen. -
USB-C
Power your device or connect to an external display from just one USB-C port with 5 Gb/s signaling rate. And it's reversible, so you never have to worry about plugging in upside down. -
32 GB eMMC storage
An embedded Multimedia Card provides reliable flash-based storage at a great value. And without the moving parts of a traditional hard drive, there's a lower chance of failure and damage.
- HP Chromebook x360 14-da0001na - 14" - Intel Pentium Gold - 4415U - 4 GB RAM - 32 GB eMMC - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS - English
- Processor
- Intel Pentium Gold 4415U / 2.3 GHz / 2 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 14" WLED touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 610
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell - up to 14 hours
- Matte, ceramic white (cover), anodised aluminium keyboard cover, mist blue ( base and keyboard frame)
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 32.54 cm x 22.68 cm x 1.6 cm
- 1.68 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - pick-up and return
- Product Type
- Operating System
- Google Chrome OS - English
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
Storage
- Main Storage
- 32 GB eMMC
Display
- 14" - IPS
- LCD Backlight Technology
- WLED backlight
- Touchscreen
- Yes (multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Edge-to-edge glass, Micro Edge
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Camera Features
- HP Wide Vision HD
- Sound
- Stereo speakers, dual array microphone
- Audio Features
- Output: Bang & Olufsen Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad, touchpad with gesture support
Communications
- Wireless
- Technology
- 3-cell lithium polymer
- Capacity
- 60.9 Wh
- Run Time
- Up to 14 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- 2 x USB-C 3.1 Gen 1 (charging) , USB 3.1 Gen 1 (Sleep & Charge) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- Power adapter
- Localization
- 1.68 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
