HP Chromebook N3060 4GB 16GB 11.6" Chrome System
Quicklinx: DD3CWS00 Mfr#: Z2Y95EA#ABU
  • Celeron
  • IEEE 802.11n
With the HP Chromebook the best of Google is at hand on a colorfully sleek and stylish notebook. Access your favorite websites instantly on a beautiful 11-inch diagonal HD display.
  • It gets high marks for durability
    Be prepared for daily bumps and dings with co-molded rubber edges and a keyboard resistant to minor spills in a Chromebook that is designed to pass MIL-STD 810G testing.
  • Touch is here
    Use the optional IPS touchscreen to give students and educators access to a world of educational Android touch-enabled apps that are now compatible with the Chrome OS .
  • Inspire learning through collaboration
    Collaborate easily with the optional wide-angle IPS touchscreen and 180° hinge design that also helps reduce stress on the lid. Make the most of Google Hangouts and video interaction with noise suppression features that improve audio clarity.
  • Simplify deployments
    Speed, simplicity, security, and easy sharing are core subjects for the Chrome OS , a low-maintenance, highly-manageable platform with automatic software updates and virus protection.
HP Chromebook 11 G5 - Education Edition - 11.6" - Celeron N3060 - 4 GB RAM - 16 GB eMMC - QWERTY UK
Chromebook
Operating System
Chrome OS - English
Intel Celeron N3060 / 1.6 GHz (2.48 GHz) / 2 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
16 GB - eMMC
Display
11.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 400
Input Device
ClickPad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
3-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip
Black, green
30 cm x 20.67 cm x 2.04 cm
1.23 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.48 GHz
Number of Cores
Dual-Core
Cache
L2 - 2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
Max RAM Supported
4 GB
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
16 GB SSD - (eMMC)
Display
11.6" - TN
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Frame Rate
30 frames per second
Camera Features
HP TrueVision HD
Sound
Stereo speakers, two microphones
Codec
Realtek ALC5650
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
QWERTY UK
Multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell
44 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
2 x USB 3.1 Gen 1 (HP USB Boost) , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 2 years)
Black, green
Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
UL, VCCI, BSMI, GOST, FCC, WEEE, A-Tick, ICES, RoHS2
Localization
1.23 kg
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
