HP Chromebook 11A G6 AMD A4-9120C 4GB 32GB - Education Edition
Quicklinx: F3Y2WS00 Mfr#: 6MR25EA#ABU
Display Size: 11.6in
Processor Model: A4-9120C
Operating System: Google Chrome OS 64
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 32GB
  • IEEE 802.11n
£221.17 ex VAT
£265.40 inc VAT
Foster creativity, collaboration, and learning with the durable, powerful HP Chromebook 11A G6 EE. Designed with co-molded rubber, reinforced corners, and a manageable, secure, and intuitive Chrome OS™, it enables access to thousands of educational Android™ apps and has universal USB-C™ connectivity and charging.
  • All decked out for the day ahead
    Give students a sleek Chromebook that redefines rugged. It measures just <19mm thin and has co-molded rubber contact points, a strengthened corner design, durable 180° hinge, and undergoes MIL-STD 810G and 70 cm drop on concrete testing.
  • Power through every project
    Quickly launch apps, support fast web browsing, and efficiently manage battery life with the AMD A4-9120C APU processor, 4 GB memory, and eMMc storage up to 32 GB.
  • Encourage collaborative learning
    Enable engaging group discussions with an optional HD IPS touchscreen that supports easy viewing from multiple angles and a 180° hinge that lies completely flat. Connect in dense environments with 2x2 802.11ac wireless and MIMO.
  • Universal connectivity and charging with USB-C
    Use the USB-C port to access and charge your USB-C accessories from your Chromebook or charge your Chromebook from any USB-C adapter.
HP Chromebook 11A G6 - Education Edition - 11.6" - A4 9120C - 4 GB RAM - 32 GB eMMC - UK
Chromebook
Operating System
Chrome OS 64 - English
AMD A4 9120C / 1.6 GHz (2.4 GHz) / 1 MB Cache
4 GB DDR4 (provided memory is soldered)
Storage
32 GB - eMMC
Display
11.6" WLED 1366 x 768 / HD
Graphics
AMD Radeon R4
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell - up to 10 hours
30.6 cm x 20.8 cm x 1.81 cm
1.28 kg
Environmental Standards
TCO Certified Notebooks 8
Chromebook
Operating System
Google Chrome OS 64 - English
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
1 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2166 MHz
Rated Speed
2166 MHz
Storage
Main Storage
32 GB SSD - (eMMC)
Display
11.6" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
Audio & Video
Graphics Processor
AMD Radeon R4
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, array microphone
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, multi-touch touchpad, gesture function, pick resistant
Communications
Wireless
Bluetooth Class
Class 2
Miracast
IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
2-cell lithium polymer
47.36 Wh
Run Time
Up to 10 hours
AC Adapter
Input
Output
45 Watt, 5 / 9 / 12 / 15 V
Connections & Expansion
2 x USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , 2 x USB 2.0 , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Classroom Management, Google Drive (100 GB Cloud Storage) (free for 2 years)
Google H1 security chip
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.28 kg
TCO Certified
Optical Storage: None
Graphics: AMD Radeon R4
Hard Drive Type: SSD
Brand: HP
Price Range Ex VAT: 150 - 300
