Elevate learning in and out of the classroom and empower students to think critically and work collaboratively with the HP Chromebook 11 EE. It's ready for class with interactive tools and a rugged design that includes co-molded rubber edges.
It gets high marks for durability
Be prepared for daily bumps and dings with co-molded rubber edges and a keyboard resistant to minor spills in a Chromebook that is designed to pass MIL-STD 810G testing. -
Touch is here
Use the optional IPS touchscreen to give students and educators access to a world of educational Android touch-enabled apps that are now compatible with the Chrome OS . -
Inspire learning through collaboration
Collaborate easily with the optional wide-angle IPS touchscreen and 180° hinge design that also helps reduce stress on the lid. Make the most of Google Hangouts and video interaction with noise suppression features that improve audio clarity. -
Simplify deployments
Speed, simplicity, security, and easy sharing are core subjects for the Chrome OS , a low-maintenance, highly-manageable platform with automatic software updates and virus protection.
- HP Chromebook 11 G5 Education Edition - 11.6" - Intel Celeron - N3060 - 4 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS - English
- Processor
- Intel Celeron N3060 / 1.6 GHz, up to 2.48 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD - 135 ppi
- Graphics
- Intel HD Graphics 400
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell - up to 11 hour(s)
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 30 cm x 20.67 cm x 2.04 cm
- 1.23 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year , Limited warranty - battery - 1 year
- Product Type
- Chromebook
- Operating System
- Google Chrome OS - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.48 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Pixel Density (ppi)
- 135
- Image Brightness
- 220 cd/m²
- Slim Design, HD ultra wide-viewing angle (UWVA) BrightView eDP
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Frame Rate
- 30 frames per second
- Camera Features
- Noise reduction, echo reduction, HP TrueVision HD
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 44 Wh
- Run Time
- Up to 11 hour(s)
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB 3.0 (charging) , USB 3.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Google Drive (100 GB Cloud Storage) (free for 2 years)
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, CCC, FCC, RoHS, MIL-STD 810G, Directive 2011/65/EC, WEEE 2002/96/EC, EN ISO 11680
- Localization
- 1.23 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
HP 90W Smart AC Adapter | In Stock | £20.26 |
HP 65W Smart AC Adapter | In Stock | £17.30 |
Other bundles (1)
HP USB Travel Mouse | In Stock | £9.28 |
