Deploy with confidence. HP Installation Service gives you the assurance that your products are off to a solid start, installed, and configured by an HP specialist. This service includes the basic installation of HP-branded hardware and software, plus HP-supported products from other vendors that are sold by HP or by HP authorized resellers.
Have confidence from the start
Keep your IT people focused on core business tasks while you avoid the hassle of setting up your own printer. Plus, you get the added assurance your product has been expertly installed by a certified HP technical specialist. -
Readiness verification prior to install
Verification prior to installation that all service prerequisites are met. -
Convenient and flexible scheduling
With our convenient and flexible scheduling, your printer can be delivered at a time that works best for you and with minimal disruption to your business. -
Let HP configure your printer
Keep your team focused on your business. An HP certified specialist will configure your printer to work within your network.
- Electronic HP Care Pack Installation Service - installation / configuration
- Installation / configuration
- Designed For
- DesignJet 130, 130r, Studio, T100, T120, T125, T130, T210, T230, T250, T520, T520 ePrinter, T525, T530, T630, T650, T730, T830, T850, T850 MFP
Details
- Installation , Configuration
- Designed For
- HP DesignJet 130, 130r, Studio, T100, T120, T125, T130, T210, T230, T250, T520, T520 ePrinter, T525, T530, T630, T650, T730, T830, T850, T850 MFP
