HP C50LE Suse Linux Thin Client u
Quicklinx: 7TP7WS00 Mfr#: 902171-02L
The Wyse C50LE thin client features a separate graphic accelerator for unparalleled performance in its class. The ultra low power media system processor delivers rich multimedia and video playback up to 1080p HD resolution.
The Wyse C50LE diskless devices boot-up in seconds, provide secure user login to corporate networks and, with no moving parts, are capable of delivering a long service life-span of between 5-7 years.
  • Higher and better video performance
  • Fast start-up
  • Saving energy
    The Wyse C50LE thin client draws just under 7 watts of power and create very little heat. As a result, each Wyse C50LE thin client contributes to cooler working environments, greatly reduced carbon footprints and huge savings in energy costs when compared to equivalent PC desktops.
Dell Wyse C50LE Thin Client - DTS C7 1 GHz - 1 GB - flash 1 GB
Thin client - DTS
1 x VIA C7 1 GHz ULV
RAM
1 GB (installed) / 2 GB (max) - DDR2 SDRAM
Hard Drive
Flash 1 GB
Optical Storage
No optical drive
Graphics Controller
VIA Chrome9 HCM - up to
Audio Output
Integrated
1GbE
OS Provided
Wyse Enhanced SUSE Linux Enterprise
Software Included
Wyse Device Manager Workgroup Edition
17.7 cm x 12.1 cm x 3.4 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - 3 years
Thin client
Product Form Factor
DTS
Processor / Chipset
CPU
VIA C7
Clock Speed
1 GHz
CPU Qty
1
Max CPU Qty
1
Power Efficiency
Ultra Low Voltage (ULV)
Chipset Type
VIA VX855
RAM
Installed Size
DDR2 SDRAM
Hard Drive
Flash
1 GB / max 1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
VIA Chrome9 HCM
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Integrated
Integrated
1 x DVI-I , 4 x USB 2.0 (2 in front) , 1 x microphone , 1 x audio line-out , 1 x PS/2 mouse , 1 x PS/2 keyboard
Horizontal feet
DVI-VGA adapter
Theft/Intrusion Protection
FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
Power adapter
Operating System / Software
OS Provided
Software
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
17.7 cm
12.1 cm
3.4 cm
2.7 kg
10 °C
20 - 80%
