HP C2710 Combo Keyboard and Mouse Set
Quicklinx: F6D4WS00 Mfr#: M7P30AA#ABU
Built with strict standards and guidelines, the HP C2710 Combo Keyboard blends a sleek, modern design with life-enhancing, advanced features.
  • Simplified keyboard functions
    Dedicated hotkeys provide immediate access to your Windows features.
  • Keyboard adjusts to your angle
    Adjustable legs provide the perfect tilt for your typing comfort.
  • Mouse's scroll wheel
    Zips you through the web and documents with speed & ease.
  • Relief in the palm of your hand
    The contoured mouse's shape promotes all-day comfort.
  • Keyboard specifications
    Full size keyboard; USB wireless receiver at 2.4 GHz; Installation made super simple. Just plug it in and hit connect.
  • Mouse specifications
    Standard 3 buttons; Optical sensor (1600 DPI max); USB wireless receiver at 2.4 GHz; 12-month battery life.
HP C2710 Combo - keyboard and mouse set - UK Input Device
Keyboard and mouse set
2.4 GHz
Wireless Receiver
Wireless
Localization and Layout
Pointing Device
Mouse - wireless
Buttons Qty
3
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 44 cm x 15.1 cm x 2.4 cm / 450 g , Mouse: 11 cm x 7 cm x 5.2 cm / 80 g
Wireless
Region
United Kingdom
Pointing Device
Mouse - wireless
Buttons Qty
3
Movement Resolution
1600 dpi
Microsoft Windows XP / Vista / 7 / 8 / 10
Shipping Width
50.2 cm
Shipping Depth
15.8 cm
Shipping Height
4.2 cm
Shipping Weight
0.7 kg
