HP Business Slim Keyboard with Smart reader
Quicklinx: D552WS00 Mfr#: Z9H48AA#ABU
Type: Keyboard
Colour: Black
£49.88 ex VAT
£59.85 inc VAT
Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar layout, function keys, and number pad into a space-saving design. Updated key light indicators alert you when Caps lock, Num lock, and Scroll are on or off. Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out.
  • Bold redesign
  • Smart security
    Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out. Compatibility with Class A, B, and C smart cards helps prevent hacking and firmware changes in the keyboard.
  • Quiet and durable
    Keep your work environment quiet with lubricated keys, and breathe easy when minor spills happen with the built-in spill drain that makes the keyboard easy to clean.
  • USB connectivity
    Easily connect the keyboard to any USB port on your PC. The included 6 ft (1.8 m) USB cable gives you plenty of room to move the keyboard around your workspace.
  • World-class support
    Enjoy the reassurance of a one-year limited warranty.
HP Business Slim - keyboard - UK - black
Keyboard
USB
Wired
Localization and Layout
Security Devices
Smart card reader
44.06 cm x 14.45 cm x 1.98 cm
600 g
1-year warranty
HP 260 G4, t540, Z1 G8; EliteDesk 705 G4, 705 G5, 800 G4, 800 G5, 800 G8, 805 G6; EliteOne 1000 G2, 800 G4, 800 G5, 800 G6, 800 G8; Engage One Pro; ProDesk 40X G4, 40X G6, 600 G5, 600 G6; ProOne 400 G4, 400 G5, 400 G6, 440 G5, 440 G6, 600 G5, 600 G6; Workstation Z1 G5, Z1 G6, Z1 G8, Z2, Z2 G4
Keyboard
USB
Input Device
Security Devices
Smart card reader
44.06 cm
14.45 cm
1.98 cm
600 g
Cable Length
1.8 m
FCC Class B certified, CSA, TUV, TUV GS, VCCI, BSMI, KCC, ICES, cULus, EAC, RCM, ISO 9241-410
Limited warranty - 1 year
10 °C
50 °C
10 - 90% (non-condensing)
HP 260 G4, t310 G2, t530, t540, Z1 G8 , HP EliteDesk 705 G3, 705 G4, 705 G5, 800 G3, 800 G4, 800 G5, 800 G8, 805 G6 , HP EliteOne 1000 G1, 1000 G2, 800 G3, 800 G4, 800 G5, 800 G6, 800 G8 , HP Engage One Pro , HP ProDesk 400 G4, 400 G5, 400 G6, 405 G4, 405 G6, 600 G3, 600 G4, 600 G5, 600 G6 , HP ProOne 400 G3, 400 G4, 400 G5, 400 G6, 440 G5, 440 G6, 600 G3, 600 G5, 600 G6 , HP Workstation Z1 G5 Entry, Z1 G6 Entry, Z1 G8, Z1 G8 Entry, Z2 G4, Z2 Mini G4 Entry, Z2 Mini G4 High Performance, Z2 Mini G4 Performance
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D552 043944
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £7.00
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Type: Keyboard
Colour: Black
Brand: HP
Stock Status: Used Stock
