HP Business Slim Keyboard with Smart reader
Quicklinx: D552WS00 Mfr#: Z9H48AA#ABU
Device Type: Other, Desktop Computer, Laptop
Type: Keyboard
Device Screen Size: [N/A]
Colour: Black
£50.56 ex VAT
£60.67 inc VAT
Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar layout, function keys, and number pad into a space-saving design. Updated key light indicators alert you when Caps lock, Num lock, and Scroll are on or off. Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out.
  • Bold redesign
  • Smart security
    Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out. Compatibility with Class A, B, and C smart cards helps prevent hacking and firmware changes in the keyboard.
  • Quiet and durable
    Keep your work environment quiet with lubricated keys, and breathe easy when minor spills happen with the built-in spill drain that makes the keyboard easy to clean.
  • USB connectivity
    Easily connect the keyboard to any USB port on your PC. The included 6 ft (1.8 m) USB cable gives you plenty of room to move the keyboard around your workspace.
  • World-class support
    Enjoy the reassurance of a one-year limited warranty.
HP Business Slim - keyboard - UK - black Input Device
Keyboard
USB
Wired
Localization and Layout
Security Devices
Smart card reader
44.06 cm x 14.45 cm x 1.98 cm
600 g
1-year warranty
HP 260 G4, 34, t540, Z1 G8, Z1 G9; Elite 600 G9, 800 G9; EliteDesk 705 G5, 800 G3, 80X G6, 80X G8; EliteOne 800 G6, 800 G8; Engage One Pro; Pro 260 G9, 400 G9; ProDesk 405 G8, 40X G6, 600 G6; ProOne 400 G5, 400 G6, 440 G5, 440 G6, 440 G9, 600 G6; Workstation Z1 G5, Z1 G6, Z2; ZBook Fury 15 G8, 17 G8
Keyboard
USB
Region
United Kingdom
Security Devices
Smart card reader
44.06 cm
14.45 cm
1.98 cm
600 g
Cable Length
1.8 m
FCC Class B certified, CSA, TUV, TUV GS, VCCI, BSMI, KCC, ICES, cULus, EAC, RCM, ISO 9241-410
Limited warranty - 1 year
10 °C
50 °C
10 - 90% (non-condensing)
HP 260 G4, 34, t310 G2, t530, t540, Z1 G8, Z1 G9 , HP Elite 600 G9, 800 G9 , HP EliteDesk 705 G3, 705 G4, 705 G5, 800 G3, 800 G4, 800 G5, 800 G6, 800 G8, 805 G6, 805 G8 , HP EliteOne 1000 G1, 1000 G2, 800 G3, 800 G4, 800 G5, 800 G6, 800 G8 , HP Engage One Pro , HP Pro 260 G9, 400 G9 , HP ProDesk 400 G4, 400 G5, 400 G6, 405 G4, 405 G6, 405 G8, 600 G3, 600 G4, 600 G5, 600 G6 , HP ProOne 400 G3, 400 G4, 400 G5, 400 G6, 440 G5, 440 G6, 440 G9, 600 G3, 600 G5, 600 G6 , HP Workstation Z1 G5 Entry, Z1 G6 Entry, Z2 G4, Z2 Mini G4 Entry, Z2 Mini G4 High Performance, Z2 Mini G4 Performance , HP ZBook Fury 15 G8 Mobile Workstation, 17 G8 Mobile Workstation
Device Type: Other
Device Type: Desktop Computer
Device Type: Laptop
Type: Keyboard
Colour: Black
Brand: HP
