HP Basic Upgrade to Data Protector Express V5 for 1 S
Quicklinx: 7C53WS00 Mfr#: TC333AAE
Do you want to make backup and recovery an essential part of your routine but without the hassle of complicated software procedures and limited staff expertise? HP Data Protector Express Basic Software delivers backup and recovery that is easy to install, use and manage. It is included with all HP tape drives, tape autoloaders, MSL2024 and MSL4048 tape libraries. It supports all the advanced features of the tape products and enables easy and reliable protection of a single machine. Data Protector Express Basic Software is exclusively available with these HP tape products and is not available through any other source. Data Protector Express Basic Software is a simplified version of Data Protector Express. If you need to protect more than one machine or use the additional features in Data Protector Express, it is easy to upgrade Data Protector Express Basic Software to Data Protector Express.
  • Unique, Only Available with HP Tape Products
    HP Data Protector Express Basic Software is exclusively included with all HP tape drives, all HP tape autoloaders, HP MSL2024 tape libraries and HP MSL4048 tape libraries.No other tape drive vendor delivers a more complete solution backup and recovery software. HP tape products include everything needed to get started; a data cable, a power cable, a data cartridge, a cleaning cartridge, documentation and HP Data Protector Express Basic Software.Data Protector Express Basic Software is based on the powerful, yet simple Data Protector Express backup and recovery software. It is a simplified version that includes all the features needed to protect one machine.
  • Delivers Tremendous Value
    HP Data Protector Express Basic Software is delivered on a CD with all of the HP tape products; all recipients can register for a zero cost license key to permanently enable the software.There is a discounted part number available to upgrade from Data Protector Express Basic Software to full featured Data Protector Express product. This delivers the same functionality as Data Protector Express for one server at a reduced price compared to the regular buy price.Data Protector Express Basic Software is easy to use and manage which means that no specialist skills or training are needed to implement a robust backup process.
  • A Complete Protection Solution for a Single Machine
    HP Data Protector Express Basic Software supports all the features of the HP tape drives such as encryption, compression, WORM and One Button Disaster Recovery (OBDR).Data Protector Express Basic Software includes Data Protector Express Bare Metal Disaster Recovery capability supports the tape drive's One Button Disaster Recovery (OBDR) feature to enable automated system recovery after a serious hardware or software failure.Windows and Linux are both supported with the Data Protector Express Basic Software.
  • Powerful Yet Easy to Use
    Data Protector Express Basic Software can be installed in minutes. Registration and license key redemption is both fast and easy.Data Protector Express Basic Software includes pre-defined and customizable media rotation schemes for recovery of multiple versions of data and to manage how long backups are retained.Data Protector Express Basic Software can deliver up to four parallel data streams to keep high-speed tape drives streaming.
HPE Data Protector Express (v. 5.0) - product upgrade licence and media - 1 server
Product upgrade licence and media
Category
Networking applications - storage management
Version
5.0
Licence Qty
1 server
Platform
Linux, Windows
Distribution Media
Electronic
ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL165 G7 Performance, DL360 G7, DL380 G7, DL380 G7 Special Server; StorageWorks SB1760c Tape Blade
Category
Version
5.0
Platform
Linux, Windows
Distribution Media
Electronic
Licencing
Licence Qty
1 server
Supported OS
SuSE Linux Enterprise Server 10.2, Microsoft Windows Server 2003 R2 SP2, SuSE Linux Enterprise Server 11, Microsoft Windows Vista SP2, Microsoft Windows XP SP3, Red Hat Enterprise Linux 6, Microsoft Windows 7 SP1, Microsoft Windows Small Business Server 2003 R2 SP2, Microsoft Windows Small Business Server 2011, Microsoft Windows Server 2008 R2 SP1
Additional Requirements
CD-ROM, 1024 x 768 monitor resolution
HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL165 G7 Performance, DL360 G7, DL380 G7, DL380 G7 Special Server , HPE StorageWorks SB1760c Tape Blade
