HP B250 Mounting Kit for LCD Display/Thin Client
Quicklinx: H566WS00 Mfr#: 8RA46AA
More than 50 In Stock
£19.60 ex VAT
£23.52 inc VAT
Customize an altogether better solution with the HP B250 PC Mounting Bracket, which lets you attach your HP Workstation, HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind select HP P series Monitors.
HP B250 mounting kit - for LCD display / thin client - HP black
Mounting kit
Mounting Components
Mount bracket
11.5 cm x 5.7 cm x 18.13 cm
505 g
Recommended Use
VESA Mounting Interface
100 x 100 mm
HP black
Package Content
4 x 6 mm screws, 4 x 10 mm screws, DisplayPort cable (70 cm), TR screws
1-year warranty
HP 260 G4; Elite 600 G9, 800 G9; Pro 260 G9; ProDesk 405 G8
11.5 cm
5.7 cm
18.13 cm
505 g
HP black
Package Content
AV Furniture
Mounting kit
Mounting Components
Mount bracket
Recommended Use
100 x 100 mm
Dimensions & Weight Details
25.5 cm x 13.5 cm x 8.5 cm / 687 g
Limited warranty - 1 year
HP 260 G4 , HP Elite 600 G9, 800 G9 , HP Pro 260 G9 , HP ProDesk 405 G8
Brand: HP
