HP AMD Radeon R9 350 graphics card - Radeon R9 350 - 2 GB
Quicklinx: CKK8WS00 Mfr#: N3R91AA
Drive your everyday PC, Web conferencing, and video or photo content to up to two displays from one card with the AMD Radeon R9 350 2GB PCIe x16 Card.
Get dual-display support plus enhanced HDCP content security from the Dual-Link DVI and DisplayPort connectors. Conveniently expand your connectivity to HDMI, DVI, and VGA displays from the DisplayPort connector with optional adapters.
Experience peak bandwidth support from the full 16-lane PCIe 3.0 bus. Eliminate the need to share PC system memory with 2 GB of dedicated GDDR5 memory.
Work with your familiar tools with a card that supports OpenGL 4.3 and DirectX 12 applications.
  • Flexible connectivity
  • Smart memory
  • Broad application support
AMD Radeon R9 350 - graphics card - Radeon R9 350 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 350 - up to
2 GB GDDR5
Core Clock
925 MHz
Effective Memory Clock
1125 MHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , 2 x DisplayPort , VGA - with adapter
API Supported
OpenCL 1.2, DirectX 11.1, OpenGL 4.3
1-year warranty
HP 4000 Pro; Business Desktop dc5800; EliteDesk 705 G2 (micro tower), 705 G3 (micro tower), 800 G2 (tower); ProDesk 400 G3 (micro tower), 490 G3 (micro tower), 600 G2 (micro tower)
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R9 350
Core Clock
925 MHz
Max Resolution
4096 x 2160 at 60 Hz
4
Interfaces Details
API Supported
AMD Unified Video Decoder (UVD)
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
1125 MHz
Bus Width
128-bit
Microsoft Windows 7 (32/64 bits), Windows 8.1 64-bit Edition, Windows 10 64-bit Edition
Additional Requirements
Adjacent PCI slot
58 Watt
UL, VCCI, BSMI, ACA, CISPR, ICES, KC
Limited warranty - 1 year
HP EliteDesk 705 G2 (micro tower), 705 G3 (micro tower), 800 G2 (tower) , HP ProDesk 400 G3 (micro tower), 490 G3 (micro tower), 600 G2 (micro tower) , HP Compaq 4000 Pro , HP Compaq Business Desktop dc5800
