HP Active Pen - Digital pen - 2 buttons - for Elite x2 1012
Quicklinx: CKKTWS00 Mfr#: T4Z24AA
Write naturally, launch an app with the touch of a button, and maximize your mobile productivity with the HP Active Pen with App Launch.
Use the pen to write or draw onscreen or interact with your touch applications. Integrated pressure sensors help you control the width of your drawn lines.
Launch an app on your tablet from your pen with a programmable Bluetooth® feature that you can pair with your choice of frequently-used software.
Once in range, your tablet1 detects the pen and cues you where to place it onscreen. Erase, highlight, and click on your content with the two convenient side buttons.
Rest easy with a one-year limited warranty.
Compatible with the HP Elite x2 1012 G1.
HP Active Pen - digital pen
Digital pen
0.95 cm 14.729 cm
17.5 g
Buttons Qty
2
Pressure sensitive pen, application launcher
AAAA type
1-year warranty
Sprout Pro by HP G2; HP 240 G6 Notebook; Elite x2 1012 G1, 1012 G2; EliteBook x360 1012 G2 Notebook, 1020 G2 Notebook, 1030 G2 Notebook, 1030 G3 Notebook; MX12 Retail Solution; Pro x2 612 G2
Digital pen
0.95 cm
14.729 cm
17.5 g
Input Device
Buttons Qty
2
AAAA battery, 3 additional pen tips, tool to exchange tips
AAAA type
Limited warranty - 1 year
Sprout Pro by HP G2 , HP 240 G6 Notebook , HP Elite x2 1012 G1, 1012 G2 , HP EliteBook x360 1012 G2 Notebook, 1020 G2 Notebook, 1030 G2 Notebook, 1030 G3 Notebook , HP MX12 Retail Solution , HP Pro x2 612 G2
