HP 980 Ink Cartridges with HP pigment inks are formulated to produce quality colour documents for up to half the cost per page of lasers. Keep your HP Officejet Enterprise printer performing at top speed to deliver consistent, durable prints.
Real savings, page after page
Lock in quality for up to half the cost per page of color lasers. These original HP pigment inks are designed to deliver quality with high cost savings - and help keep your HP Officejet enterprise printer or MFP running at top speed. -
Quality you can rely on
Expect the best from the cartridge your HP Officejet enterprise printer is designed to use. Print crisp, colorful documents that dry fast resist water and last for decades, using original HP pigment ink cartridges. -
Loaded for productivity, ready for business
Just keep printing - install in seconds and print up to 10000 pages per cartridge. Conserve paper with the HP smart print tool and stay ahead of supplies ordering with HP web Jetadmin remote monitoring of ink levels. -
Make a positive impact
Choose cartridges that use fewer resources. Reduce packaging waste up to 90% compared with toner cartridges and easily recycle your original HP ink cartridges for free through HP planet partners.
- HP 980 - yellow - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Yellow (pigmented)
- Capacity
- 86.5 ml
- Yield
- Up to 6600 pages ISO/IEC 24711
- Compatible with
- Officejet Enterprise Color MFP X585dn, MFP X585f, X555dn, X555xh; Officejet Enterprise Color Flow MFP X585z; Officejet Managed Color MFP X585dnm; Officejet Managed Color Flow MFP X585zm
- Dimensions (WxDxH) / Weight
- 180 g
- Shipping Width
- 24.17 cm
- Shipping Depth
- 2.87 cm
- Shipping Height
- 7.16 cm
- Shipping Weight
- 200 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Included Qty
- 1-pack
- Capacity
- 86.5 ml
- Yield
- Compatible with
- HP Officejet Enterprise Color MFP X585dn, MFP X585f, X555dn, X555xh , HP Officejet Enterprise Color Flow MFP X585z , HP Officejet Managed Color MFP X585dnm , HP Officejet Managed Color Flow MFP X585zm
