HP 933XL High Yield Yellow Original Ink Cartridge
Quicklinx: 858CWS00 Mfr#: CN056AE#BGX
Type: Ink Cartridge
Technology: Ink-Jet
£17.87 ex VAT
£21.44 inc VAT
HP 933 Yellow Officejet Ink Cartridge prints with professional-quality colour on page after page. Bring documents and marketing materials to life with outstanding colour vibrancy for a low cost per page and easily recycle your cartridges.
  • Designed to work the first time, every time
    Be assured that Original HP Cartridges will consistently deliver quality results and premium performance.
  • Quality prints you can take pride in
    Experience premium print quality with Original HP Cartridges designed for vibrant colour, crisp text, and rich blacks for big impact.
  • The environmental choice
    Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste.
  • Better together. Better results
    Original HP Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance.
  • Consistent quality every print
    Get dependable, high-quality results with every print. Use Original HP inks for consistency page after page.
  • Ink alerts
    When an ink cartridge is running low, your printer will be alerted so you can replace ink before mid-page.
HP 933XL - High Yield - yellow - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Yellow
Cartridge Yield
High Yield
Yield
Up to 825 pages
Compatible with
Officejet 6100 ePrinter, 6600 H711a, 6700 Premium H711n, 7110 Wide Format ePrinter, 7510 Wide Format, 7610 Wide Format, 7612 Wide Format
Shipping Width
94 mm
Shipping Depth
25 mm
Shipping Height
126 mm
Shipping Weight
50 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Yellow
Included Qty
1-pack
Cartridge Yield
High Yield
Yield
Up to 825 pages
Compatible with
HP Officejet 6100 ePrinter, 6600 H711a, 6700 Premium H711n, 7110 Wide Format ePrinter, 7510 Wide Format, 7610 Wide Format, 7612 Wide Format
Type: Ink Cartridge
Technology: Ink-Jet
Brand: HP
