Simple to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Easy to carry and store
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
- HP USB-C - power adapter - 90 Watt
- Power adapter - external
- Localisation
- English / United Kingdom
- Input Voltage
- AC 115/230 V
- Output Voltage
- 5 / 9 / 10 / 12 / 15 / 20 V
- Power Capacity
- 90 Watt
- 12.95 cm x 6.55 cm x 2.85 cm
- Designed For
- Elite x2 1012 G2; EliteBook 1040 G4 Notebook; EliteBook x360 1020 G2 Notebook, 1030 G2 Notebook; Engage One Pro; MX12 Retail Solution; Pro c640 G2 Chromebook, c640 G2 Chromebook Enterprise; Pro x2 612 G2; ProBook 640 G4 Notebook, 645 G4 Notebook, 650 G4 Notebook
- Localisation
- Input Voltage
- AC 115/230 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- Max Electric Current
- 5 A
- Power Capacity
- 90 Watt
- Efficiency
- 81.5% min at AC 115/230 V (5V), 86.7% min at AC 115/230 V (9V), 88% min at AC 115/230 V (10V), 88% min at AC 115/230 V (12V), 89% min at AC 115/230 V (15V), 89% min at AC 115/230 V (20V)
- MTBF
- 200,000 hours
- FCC Class B certified, EN 60950, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, cULus, LVD, NOM-1-NYCE
- 0 °C
- 35 °C
- 12.95 cm
- 6.55 cm
- 2.85 cm
- Designed For
- HP Elite x2 1012 G2 , HP EliteBook 1040 G4 Notebook , HP EliteBook x360 1020 G2 Notebook, 1030 G2 Notebook , HP Engage One Pro , HP MX12 Retail Solution , HP Pro c640 G2 Chromebook, c640 G2 Chromebook Enterprise , HP Pro x2 612 G2 , HP ProBook 640 G4 Notebook, 645 G4 Notebook, 650 G4 Notebook
