HP 90W Smart AC Adapter
Quicklinx: BKSHWS00 Mfr#: H6Y90AA#ABU
Device Type: Laptop
Type: Power Adapter
Device Screen Size: [N/A]
Colour: Black
More than 50 In Stock
£19.95 ex VAT
£23.94 inc VAT
Provide optimal power and help offset power fluctuations to your HP notebook with a HP 90W Smart AC Adapter. Now available with a new right-angled (90°) connector that reduces cable stress and an optional 4.5mm to 7.4mm conversion dongle. As a replacement or back-up adapter, be prepared with the right connection.
  • Controlled and efficient flow
    Operate with confidence with optimal performance using smart-pin technology and reduce the risk of power surges, while drawing only minimal power as needed.
  • Connection for today and yesterday
    Connection versatility with a specially designed dongle allowing for simple conversion from the new standard 4.5mm connector to HP predecessor notebooks with 7.4mm connectors.
  • The perfect right turn
    Tight access made convenient – the new right-angled (90°) 4.5mm connector allows for connecting in limited spaces and reduces cord bending providing better cable management and longevity.
HP Smart AC Adapter - power adapter - 90 Watt
Power adapter - external
370 g
English / United Kingdom
Output Voltage
19 V
Power Capacity
90 Watt
4.5mm to 7.4mm power DC dongle
12.7 cm x 5 cm x 2.9 cm
HP 340 G5 Notebook, 348 G5 Notebook; EliteBook Folio 1020 G1, 1040 G2; ProBook 445r G6 Notebook, 455r G6 Notebook, 640 G5 Notebook, 650 G5 Notebook
Output Voltage
19 V
Power Capacity
90 Watt
Power cable
Over voltage protection
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
20 - 80%
12.7 cm
5 cm
2.9 cm
370 g
Shipping Weight
0.7 kg
HP 340 G5 Notebook, 348 G5 Notebook ¦ HP EliteBook Folio 1020 G1, 1040 G2 ¦ HP ProBook 445r G6 Notebook, 455r G6 Notebook, 640 G5 Notebook, 650 G5 Notebook
Device Type: Laptop
Type: Power Adapter
Colour: Black
Brand: HP
