HP 8760W Intel® Core™ i7-2670QM Processor, 4GB, 500GB, 17.3", Windows 7 Professional 64-bit
Quicklinx: 7ZPJWS00 Mfr#: LY530ET#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Generate intensive animation, multi-dimensional engineering plans, and complex designs with this powerful HP EliteBook 8760w Mobile Workstation. This mobile workstation boasts expanded memory capacity and high-performance graphics.
  • Equipped to get the job done
    The 17.3-inch diagonal display with processor capabilities culminate to meet your business needs.
  • Chiseled design exudes power
    No need to worry about bumps, drops or scuffs. The purposeful design of the HP EliteBook translates into true business ruggedness. The gunmetal casing and military-grade testing drop, vibration, dust, altitude and high temperature helps ensure your notebook can survive rough travels and harsh work locations.
  • Consistent, accurate color
    HP DreamColor technology makes it easy to work in many different color spaces and ensure consistent color appearance from concept to design to production.
  • Improve productivity and performance
    Runs more tasks, processes and applications simultaneously with a mobile workstation that brings together and optimizes Core i7 processor and professional graphics. SRS Premium Sound delivers an audio experience for users listening to media rich content or presenting multimedia heavy presentations and for digital content creators listening to audio or surround sound the way it was meant to be heard.
HP EliteBook 8760w Mobile Workstation - 17.3" - Intel Core i7 - 2670QM - 4 GB RAM - 500 GB HDD
Mobile workstation
Operating System
Win 7 Pro 64-bit
Intel Core i7 (2nd Gen) - 2670QM / 2.2 GHz, up to 3.1 GHz / 6 MB Cache
4 GB DDR3
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight Full HD WVA anti-glare 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro 3000M
Video Memory
2 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad, pointing stick
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 2.1 EDR, Gigabit Ethernet, fax / modem
8-cell
Ambient light sensor
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
Gun metal
41.7 cm x 27.3 cm x 4.3 cm
3.6 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years
Mobile workstation
Recommended Use
Small business, corporate business
Operating System
Processor / Chipset
CPU
Intel Core i7 (2nd Gen) 2670QM / 2.2 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Chipset
Mobile Intel QM67 Express
RAM
4 GB
Max RAM Supported
32 GB
DDR3 SDRAM
Speed
1333 MHz / PC3-10600
Rated Speed
1333 MHz
SO-DIMM 204-pin
Slots Qty
4
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Full HD wide-viewing angle (WVA) anti-glare
Audio & Video
Graphics Processor
NVIDIA Quadro 3000M
Video Memory
2 GB GDDR5 SDRAM
Camera
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD87
SRS Premium Sound, High Definition Audio
Input
Numeric Keypad
Spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az
Modem
Protocols & Specifications
ITU V.21, Bell 212A, ITU V.22, ITU V.22bis, ITU V.29, ITU V.32, ITU V.32bis, ITU V.34, ITU V.17, ITU V.23, ITU V.27ter, ITU V.8bis, Bell 103J, ITU V.92, ITU T.30, ITU T.4, ITU V.250, ITU V.251, ITU V.80
Max Transfer Rate
56 Kbps
8-cell Lithium Ion
Installed Qty
1
Max Supported Qty
2
75 Wh
AC Adapter
Input
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
Slots
1 x ExpressCard/54 (1 free)
Interfaces Details
DisplayPort , VGA , FireWire , Microphone input , Headphone output , Modem , LAN , 2 x USB 3.0 , 2 x USB 2.0 , USB 2.0/eSATA , Dock , Battery
Memory Card Reader
Yes (SD Card, MultiMediaCard)
Software
Software Included
HP ProtectTools Security Manager, HP Client Manager Software (free download), Skype, HP Recovery Manager, HP Support Assistant, HP QuickWeb, HP Power Assistant, HP DayStarter, HP Connection Manager, HP SoftPaq Download Manager (free download), PDF Complete Special Edition (60 days trial), Norton Internet Security 2011 (60 days subscription), HP Hotkey Support, HP Performance Advisor, HP ProtectTools for Central Management
Gun metal
Integrated Options
Dockable
Security
Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES
Localization
HP Smart Buy
3.6 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
125 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
