HP 850 G3 Notebook Intel Core i5-6200U 8GB 240GB 15.6" Windows10 Pro - REFURB
Quicklinx: FRTXWS00 Mfr#: L3D28AV
  • Core i5
Impressively thin and light, the HP EliteBook 850 empowers users to create, connect, and collaborate, using enterprise-class performance technology that helps keep you productive in and out of the office.
  • Sleek and sturdy
    It's time for an upgrade to the dramatically thin, light design of the HP EliteBook Ultrabook with a luxurious soft-touch finish.
  • It's all about the connections
    Exercise full control over your wireless connections through a single user interface with support for most networks. Easily share your Internet connection and help colleagues get online and improve productivity.
  • Solid security
    HP SureStart restores productivity and reduces IT help desk calls in the event of a BIOS attack or corruption. HP BIOS Protection feature offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.
  • Road ready
    Never fear accidental bumps and minor spills. HP EliteBooks ensure they can withstand rigorous work environments.
HP EliteBook 850 G3 Notebook - 15.6" - Intel Core i5 - 6200U - 0 GB RAM
Notebook
Operating System
No OS
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
0 GB DDR4
Display
15.6"
Gigabit Ethernet
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, smart card reader
38.33 cm x 25.77 cm x 1.94 cm
1.84 kg
Pricing Type
CTO
Notebook
Operating System
No operating system
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
0 GB
Max RAM Supported
16 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
2
Display
15.6"
Widescreen
Audio & Video
Graphics Processor
- up to
Sound
Stereo speakers
Codec
CX7501
Audio Features
Output: Bang & Olufsen Audio, HP Clear Sound Amp
Communications
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Remote Management Protocol
SNMP 2
Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ae, IEEE 802.3az
Connections & Expansion
Interfaces Details
USB 3.1 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack , USB 3.1 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Case Material
Aluminum, magnesium alloy
Dockable
Security
HP 3D DriveGuard, HP SpareKey, HP BIOS Protection, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+
Pricing Type
CTO
1.84 kg
Sustainability Information
TCO Certified
Essential Accessories (3)
Get more from your purchase from one of our essential accessories
FRTX HP 90W Smart AC Adapter In Stock £20.26
FRTX HP 45W Adaptor NPFC Smart RC 4.5MM NSLIM In Stock £20.31
FRTX HP 65W Smart AC Adapter In Stock £17.30
Other bundles (2)
FRTX HPE DisplayPort to VGA Adapter In Stock £13.22
FRTX HP USB Travel Mouse In Stock £9.28
