HP 8300E SFF Intel Core i3-3220 500GB 4GB DVDRW W8 Pro
Quicklinx: 8JHGWS00 Mfr#: A2K84ET#ABU
  • Core i3
  • Red Hat Enterprise Linux
  • Microsoft Windows 7 Professional 64-bit Edition
A smart combination of customizable solutions for your business. Introducing the HP Compaq Elite 8300 Small Form Factor; HP's best-selling business PC design featuring an ideal blend of size, performance, and expansion capabilities.
  • Powerful performance
    Experience the 3rd generation Intel Core vPro processor family and Intel Q77 Express chipset for high-end performance without compromise.Support for dual graphics cards, and new PCI Express v3.0 graphics technology provides increased bandwidth of PCIe x16 slot for fast graphic-intensive performance.Maximize productivity with up to four independent displays with optional discrete graphics card. Convenient connectivity with line in and line out ports and front-facing USB ports with VGA and DisplayPort outputs for dual-monitor set-ups.Intel Smart Response Technology (SRT), a disk cache solution, provides solid state drive like performance while retaining the storage capacity of a hard disk drive.SRS Premium Sound provides an outstanding audio experience, including VoIP conferencing, webcasts and collaboration. Exclusive HP Virtual Room software provides face-to-face collaboration around the globe.
  • Manageability and security
    Intel vPro with Active Management Technology allows your IT personnel to access, diagnose, repair and manage the desktop from a remote location saving time and reducing maintenance cost.Secure data and credentials with HP's certified and embedded Trusted Platform Module (TPM). Disable USB ports and slots for added security.HP ProtectTools is a comprehensive portfolio of security features built into the hardware and software that can be customized to protect your data with the level of security your business needs.Drive Encryption encrypts all data in the hard drive. Permanently erase data with HP File Sanitizer. Credential Manager supports multiple authentication methods with single sign in capability into protected websites and resources.On hands management is a snap with a tool-less design. Upgrade components with the quick release latches and green pull tabs.
  • Environmentally aware
    Lower your operating costs and overall eco-footprint with HP PC that's ENERGY STAR qualified, EPEAT Gold registered, and designed with low halogen materials.Manage your energy more efficiently with HP Power Assistant software, enabling you to set up custom schedules for when the machine goes into low power states.
  • Backed by HP
    Maintain a consistent work environment, ease transitions and help reduce support costs with a minimum, 15-month lifecycle stability commitment from HP.Benefit from HP Custom Integration Services (CIS), providing stable, custom software and hardware deployment services for your enterprise needs.HP Business PCs go through a multi-tiered testing process of over 115,000 hours to help ensure a lasting investment.Rely on world-class service and support with a standard, 3-year limited warranty from HP. Additional coverage is available through HP Care Pack Services.
HP Compaq Elite 8300 - SFF - Core i3 3220 3.3 GHz - 4 GB - HDD 500 GB
Personal computer - small form factor - system password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT)
Intel Core i3 (3rd Gen) 3220 / 3.3 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 2500 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Adobe Flash Player, HP Help and Support, Microsoft Security Essentials, HP ProtectTools Security Software Suite, HP Recovery Manager, HP Support Assistant, Microsoft Office 2010 Starter, PDF Complete Corporate Edition, WinZip Basic, HP Marketplace, HP Wallpaper, HP Setup 9.0, Microsoft Advantage Program
33.8 cm x 37.9 cm x 10 cm
7.6 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Small form factor
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q77 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1600 MHz
DIMM 240-pin
Slots
4 (Total)
Unbuffered
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
SRS Premium Sound, High Definition Audio
Input Device
Mouse, keyboard
Integrated
Ethernet Controller
Intel 82579LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x external 3.5" x 1/3H
Slots
1 (total) / 1 (free) x PCI - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 2.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 0 (free) x CPU , 4 DIMM 240-pin
6 x USB 2.0 (4 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x DisplayPort , 1 x VGA , 1 x PS/2 mouse , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 4 x USB 3.0
System password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
240 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
33.8 cm
37.9 cm
10 cm
7.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
