HP 820 G1 Intel Core i5-4200U 4GB 500GB W7/W8 PRO
Quicklinx: 90TXWS00 Mfr#: H5G05ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Now employees can hit the road with a travel pro. The HP EliteBook 820 G1 industry leading thin and light notebook is ultra-mobile in and out of the office. Work with confidence thanks to proven enterprise technologies and enterprise security, performance and management features that will meet all your business needs.
  • Sleek and sturdy
    It's time for an upgrade to the dramatically thinner, lighter design of the HP EliteBook 820 with a luxurious and soft touch finish.Join forces with the latest generation Intel architecture and operate at peak performance levels with Intel Smart Response Technology for disk cache and expand total storage options with an additional mini-card SSD.Dock up for an enterprise desktop experience using the optional UltraSlim Docking Station with a convenient side connector and dual DisplayPorts for multiple display support.
  • It's all about the connections
    Exercise full control over your wireless connections through a single user interface with support for most networks, including optional new 4G WWAN, using HP Connection Manager.Easily share your internet connection with up to five devices with HP Wireless Hotspot. Help colleagues get online and improve productivity.Take productivity to a whole new level with innovative software like HP ePrint and HP PageLift on the HP EliteBook 820 G1 thin and light notebook.Bridge distances on the HP EliteBook 800 series, with Microsoft Lync, premium audio/video and optional HD Premium touch display.
  • Solid security
    HP Sure Start restores productivity and reduces IT help desk calls in the event of a BIOS attack or corruption. Developed with HP Labs, HP Sure Start helps reduce down time for users and IT.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Safeguard data, devices and identities with HP's hassle-free Client Security portfolio, including HP Drive Encryption, HP Device Access Manager with Just In Time Authentication, and HP Secure Erase.Ensure smooth sailing with stable and consistent images, managed lifecycle transitions and Global Series support you can rely on.
  • Road ready
    Never fear accidental bumps and minor spills. HP EliteBooks undergo challenging tests so you don't have to. During the HP Total Test Process, PCs experience 115,000 hours of performance trials to ensure they can withstand rigorous work environments.Designed to be travel-tough, the HP EliteBook 820 thin and light notebook features a new, soft touch finish and is designed to undergo MIL-STD 810G testing.
HP EliteBook 820 G1 Notebook - 12.5" - Intel Core i5 4200U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8 Pro) + Windows 8 Pro Licence
Intel Core i5 (4th Gen) 4200U / 1.6 GHz (2.6 GHz) / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4400
Input Device
Pointing stick
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell - up to 11.25 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
31 cm x 21.53 cm x 2.1 cm
1.33 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 3 years
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro) + Windows 8 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Display
12.5"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HD standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound
Input
Keyboard, touchpad, pointing stick
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Remote Management Protocol
SNMP 2
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell lithium polymer
46 Wh
Run Time
Up to 11.25 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
3 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Bing Toolbar, HP Connection Manager, HP Hotkey Support, HP Client Security
Case Material
Magnesium-aluminum alloy
Dockable
Security
Power-on password, HP Disk Sanitizer, HP Enhanced DriveLock, HP 3D DriveGuard, HP DuraKeys, Enhanced Pre-Boot Security, HP SpareKey, HP File Sanitizer, HP BIOS Protection, BIOS Absolute Persistence, USB 3.0 port power off USB charging
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC
Localization
1.33 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
