HP 800 G4 Core i7-8700 16GB 512GB SSD Windows 10 Pro
Quicklinx: DPXTWS00 Mfr#: 4QJ00EA#ABU
  • Core i7
  • Step up to workstation performance
    Take performance up a notch with plenty of configurations and expandability. With NVIDIA GeForce & Quadro options, you can pick the perfect GPU for the job. Plus, multiple expansion slots provide plenty of room to accommodate your evolving needs.
  • Software certified
    Work with confidence knowing your desktop is certified for your most critical applications. We've worked closely with leading software providers like Autodesk and SolidWorks to help ensure seamless and reliable performance at every stage of your workflow.
  • HP's most secure and manageable workstations
    Get powerful protection from evolving malware threats with self-healing, hardware-enforced security solutions like HP Sure Start Gen4 which protects against BIOS attacks. Plus, easily manage multiple devices with the HP Manageability Integration Kit Gen2 .
HP EliteDesk 800 G4 - tower Core i7 8700 3.2 GHz - vPro - 16 GB - SSD 512 GB - UK
Personal computer - tower
Platform Technology
Intel vPro Platform
Intel Core i7 (8th Gen) 8700 / 3.2 GHz (up to 4.6 GHz, (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
12 MB
Cache Per Processor
12 MB
RAM
16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 512 GB - SATA 6Gb/s - 2.5"
Optical Storage
DVD-Writer
Card Reader
5 in 1
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
PCIe 3.0 x16 - NVIDIA GeForce GTX 1060 / Intel UHD Graphics 630
Video Memory
3 GB GDDR5 SDRAM
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
15.4 cm x 37 cm x 36.5 cm
9.86 kg
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
4.6 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
12 MB
Cache Per Processor
12 MB
RAM
Installed Size
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Configuration Features
1 x 16 GB
Hard Drive
SSD - 2.5"
1 x 512 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Card Reader
5 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Interface Type
PCIe 3.0 x16
Graphics Processor
Video Memory
3 GB GDDR5 SDRAM
Video Interfaces
DVI, HDMI, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25" x 1/2H
Slots
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 2 (free) x M.2 Card - 2230/2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 1 (total) / 0 (free) x PCIe 3.0 x16
4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x USB 3.1 Gen 2 (1 in front) , 5 x DisplayPort , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 rear) , 1 x audio line-in (1 rear) , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x HDMI
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
CCC, RoHS, WEEE, CECP, SEPA
Power supply
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Gold
Efficiency
87% at 20% Load (115 VAC), 90% at 50% Load (115 VAC), 87% at 100% Load (115 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
15.4 cm
37 cm
36.5 cm
9.86 kg
Shipping Width
29.9 cm
Shipping Depth
47.8 cm
Shipping Height
51.7 cm
Shipping Weight
11.34 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (3)
DPXT HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £33.64
DPXT HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £68.47
DPXT HP Care Pack Next Business Day Hardware Support with Disk Retention 5 Years - On-Site In Stock £131.89
Other bundles (3)
DPXT HPE DisplayPort DVI-D Adapter In Stock £19.88
DPXT HPE DisplayPort to VGA Adapter In Stock £13.22
DPXT HPE USB to Serial Port Adapter In Stock £13.95
