HP 800 G3 SFF Intel Core i5-7500 4GB 500GB Windows 10 Pro
Quicklinx: CP4NWS00 Mfr#: Z4D04ET#ABU
  • Core i5
Experience amazing productivity plus superb reliability, security, manageability and big portfolio of solutions with the powerful HP EliteDesk 800 G2, expandable enterprise-class PC from HP.
Performance first
High-performance users will enjoy the powerful combination of 7th Gen Intel® Core™ processors, optional Intel® Optane™ memory and SSDs, and HP Velocity that improves data transfer rates over challenged networks to drive productivity in the workplace.
Expansion that extends your investment
The full value of your investment comes with configuration that extends the life of your PC. The HP EliteDesk 800 SFF has four bays and four slots, plus two additional M.2 connectors, and plenty of configurable ports.
Strong security, powerful manageability
Get powerful protection and simplified management from HP’s most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager
Configurable I/O Port for displays
Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort™, HDMI or USB Type-C™ alternate mode DisplayPort™.
  • Performance first
    High-performance users will enjoy the powerful combination of 7th Gen Intel Core processors, optional Intel Optane memory and SSDs to drive productivity in the workplace.
  • Expansion that extends your investment
  • Strong security, powerful manageability
    Get powerful protection and simplified management from HP's most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager.
  • Configurable I/O Port for displays
    Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort , HDMI or USB Type-C alternate mode DisplayPort .
HP EliteDesk 800 G3 - SFF Core i5 7500 3.4 GHz - vPro - 4 GB - HDD 500 GB - UK
Personal computer - SFF
Platform Technology
Intel vPro Platform
Intel Core i5 (7th Gen) 7500 / 3.4 GHz (up to 3.8 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit
33.8 cm x 30.8 cm x 10 cm
5.31 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
SFF
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
2 (total) / 1 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 3.1 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x audio line-out , 1 x audio line-in , 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CCC, Common Criteria EAL4+, CECP, SEPA, low halogen
HP Smart Buy
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Platinum
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
33.8 cm
30.8 cm
10 cm
5.31 kg
10 °C
35 °C
10 - 90% (non-condensing)
Warranties (7)
CP4N HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service In Stock £32.96
CP4N HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site In Stock £27.34
CP4N HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £34.13
CP4N HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site In Stock £69.44
CP4N HP Care Pack NBD HW Support w/ Defective Media Retention Extended Service Agreement 4 Years On-Site In Stock £57.67
CP4N HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 5 Years On-Site In Stock £80.03
CP4N HP Care Pack Next Business Day HW Support Extended Service Agreement 4 Year On-Site - Desktop Only In Stock £24.77
Other bundles (5)
CP4N HPE DisplayPort DVI-D Adapter In Stock £19.74
CP4N HPE DisplayPort to VGA Adapter In Stock £13.12
CP4N HPE USB to Serial Port Adapter In Stock £13.94
CP4N HP USB-C To VGA Adapter In Stock £22.81
CP4N HP USB-C to HDMI 2.0 Adapter In Stock £47.15
