HP 800 G3 DM Intel Core i7700 8GB 256GB SSD W10P
Quicklinx: CP4QWS00 Mfr#: 1CB62ET#ABU
Processor Type: Core i7
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i7
  • IEEE 802.11n
More than 50 in stock
£872.31 ex VAT
£1,046.77 inc VAT
Powered for the enterprise, the HP EliteDesk 800 is a secure and manageable PC featuring advanced performance, and configurability in a space saving, stylishly redesigned chassis for the modern workplace.
Surprisingly small, stunningly powerful
The HP EliteDesk 800 Desktop Mini is HP’s smallest and most powerful business-class desktop. Drive performance with 7th Gen Intel® Core™ processors, optional Intel® Optane™, optional 65W processor, up to 32 GB of DDR4 memory, and HP Turbo Drive G2.
Simple mounting solutions
Easily deploy your Mini behind any Elite Display for a near zero footprint solution. Mount and secure it almost anywhere with HP full ecosystem of DM accessories.
Strong security, powerful manageability
Get powerful protection and simplified management from HP’s most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager.
Configurable I/O Port for displays
Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort™, HDMI or Serial USB-Type C™ with DisplayPort™.
  • Surprisingly small, stunningly powerful
    The HP EliteDesk 800 Desktop Mini is HP's smallest and most powerful business-class desktop. Drive performance with 7th Gen Intel Core processors, optional Intel Optane , optional 65W processor, up to 32 GB of DDR4 memory, and HP Turbo Drive G2.
  • Simple mounting solutions
  • Strong security, powerful manageability
    Get powerful protection and simplified management from HP's most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager.
  • Configurable I/O Port for displays
    Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort , HDMI or Serial USB-Type C with DisplayPort .
HP EliteDesk 800 G3 - mini desktop - Core i7 7700 3.6 GHz - 8 GB - 256 GB - QWERTY UK
Personal computer - mini desktop
Platform Technology
Intel vPro Technology
1 x Intel Core i7 (7th Gen) 7700 / 3.6 GHz (4.2 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
1 x SSD 256 GB - PCI Express - M.2 - NVM Express (NVMe), triple-level cell (TLC)
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
OS Provided
17.7 cm x 17.47 cm x 3.42 cm
1.21 kg
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Personal computer
Product Form Factor
Mini desktop
Built-in Devices
Speaker, hood sensor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q270
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 0 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
2 x 4 GB
Hard Drive
SSD - M.2
1 x 256 GB
Interface Type
PCI Express
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
QWERTY UK
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card (x4 mode)
6 x USB 3.1 Gen 1 (2 front, 4 rear) (two of them with wake functionality, one of them is charging) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front)
HP Desktop Mini Vertical Chassis Stand
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI, CCC, Common Criteria EAL4+, CECP, SEPA, low halogen
Pricing Type
Promo
Power adapter
Nominal Voltage
Power Provided
90 Watt
Efficiency
89%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit
ENERGY STAR Certified
17.7 cm
17.47 cm
3.42 cm
1.21 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP 800 G3 DM Intel Core i7700 8GB 256GB SSD W10P Bundle deal on HP 800 G3 DM Intel Core i7700 8GB 256GB SSD W10P
£1,059.95
saving £8.33
£972.07
Storage Type: SSD
Processor Model: I7-7700
Type: Personal computer
Case Style: Desktop slimline
Optical Storage: None
Brand: HP
Price Range Ex VAT: 750 - 1000
