HP 800 G2 DM Intel Core i5-6500 8GB 500GB Windows 10 Professional
Quicklinx: CH2HWS00 Mfr#: X3J89ET#ABU
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
Don't sacrifice size or power. Get the best of both worlds with the high-performance HP EliteDesk 800 65W Desktop Mini. With a full line of mounting, expansion, and security accessories this PC fits almost anywhere for an enterprise-class solution.
Performance for the enterprise
Power through your day with a PC, driven by 6th Gen Intel® Core™ processors in a new powerful 65W design that also includes Intel® HD Graphics.
Security designed to deter downtime
Get maximum uptime with HP BIOSphere with SureStart, which helps stop attacks at the BIOS, HP Client Security Suite’s data protection, and multi-factor authentication.
Versatility to build a better workspace
Deploy the Mini almost anywhere with the VESA-enabled flexible mounting options including optional accessories, and VESA ready displays. Customize your solution with a full range of expandability, security, and mounting accessories.
Ready to run
This Mini endured 120,000 hours of performance trials during the HP Total Test Process and is designed to undergo MIL-STD 810G testing. Help keep your PC cool in challenging work environments with HP temperature controls.
  • A low TCO pro
    Available ENERGY STAR certified and EPEAT Gold registered models of the HP EliteDesk 800 Desktop Mini. Consume less than 8W of power at idle.
  • World-class management
    Simplify IT manageability with Intel vPro and Windows 10 Pro plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices.
  • Consistently stagger deployments
    Get the same HP configuration across the globe for your international enterprise, available in more than 180 countries where HP conducts business.
  • Create a compact, efficient workspace
    Attach your HP Desktop Mini directly behind select HP EliteDisplays.
  • Reset the performance curve
    Increase and performance with an optional powerful HP Turbo Drive that handles your growing and complex workloads.
HP EliteDesk 800 G2 - mini desktop - Core i5 6500 3.2 GHz - vPro - 8 GB - HDD 500 GB - UK
Personal computer - mini desktop
Platform Technology
Intel vPro Platform
Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 530 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Secure Erase, HP Client Security Manager
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Intel vPro Platform
Personal computer
Product Form Factor
Mini desktop
Built-in Devices
Hood sensor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Conferencing Keyboard
Localization & Layout
Mouse
Mouse Name
HP USB Mouse
USB
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Skype Certified, IEEE 802.3az, Bluetooth 4.0
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card (x1 mode) , 1 (total) / 1 (free) x M.2 Card (x4 mode)
6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x VGA , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x USB-C 3.0 (1 in front)
Vertical stand
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CCC, RoHS, WEEE, CECP, SEPA
HP Smart Buy
Power adapter
Power Provided
65 Watt
Efficiency
89%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Sustainability Information
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
