HP 7500E MT Intel® Core™ i7-3770 Processor, 4GB, 1TB, DVD±RW, WIndows 7 Professional 64-bit
Quicklinx: 85RGWS00 Mfr#: QB163EA#ABU
  • Core i7
  • Microsoft Windows 7 Professional 64-bit Edition
  • State-of-the art computing
    Your small business computing needs can change at the click of a mouse. You need a PC that can keep up. The HP Elite 7500 is designed to give you the high performance you need for today's process-intensive and graphics-rich applications and the sleek new design complements any home office or small business environment.
  • Technology for today and tomorrow
    Intel Core i3, Core i5 or Core i7 3rd Generation processors provide top speeds and multiple cores for some of the most demanding applications you'll ever need to run. Paired with the powerful Intel H67 Express Chipset, you get a PC that's affordable and performance ready.
  • Flexibility at your fingertips
    Including four memory slots, PCI Express slots, internal and external drive bays, the HP Elite 7500 Microtower Business PC is designed for customization and expansion.Data is what it is all about, and your files aren't getting any smaller. USB 3.0 ports give you higher transfer rates than USB 2.0 in order to match the new usage and larger devices being developed.The highly expandable HP Elite 7500 Microtower is intended to fit a wide range of space and configuration requirements. The sleek new design with its high-gloss finish and rounded corners is meant to be shown off.
  • Out-of-the-box productivity
    The HP Elite 7500 does all the heavy lifting with no matter how extensive a list of features you desire. Configuration options include a variety of optical drives and hard drives, and memory configurations up to 16GB. And, with preinstalled software like the HP Power Assistant, you get a PC equipped to make an impact right out of the box.
  • Give your business a boost
    With Beats Audio , HP has engineered an audio system that unlocks all of the sounds musicians and producers have perfected in the studio. You hear the highs, lows and subtle in-betweens like never before.Plus, the HP Elite 7500 offers business class service and support so you can spend your time focusing on what's most important-your business.
HP Elite 7500 - micro tower - Core i7 3770 3.4 GHz - 4 GB - HDD 1 TB
Personal computer - micro tower - system password, power-on password, DriveLock
Intel Core i7 (3rd Gen) 3770 / 3.4 GHz (3.9 GHz) (Quad-Core)
Cache Memory
8 MB
Cache Per Processor
8 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - PC3-12800
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD 1 TB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
15 in 1
Graphics Controller
Intel HD Graphics 4000 Dynamic Video Memory Technology
Audio Output
7.1 channel surround - integrated
GigE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Microsoft Office Professional 2010
16.5 cm x 37.3 cm x 36.5 cm
9.6 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower
Processor / Chipset
CPU
Clock Speed
3.4 GHz
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Z75 Express
Cache Memory
Installed Size
8 MB
Cache Per Processor
8 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3 SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
DIMM 240-pin
Slots
4 (Total)
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
15 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Standard Value Keyboard
USB
Integrated
Ethernet Controller
Realtek RTL8111E
Bays
2 (total) / 1 (free) x external 5.25" , 2 (total) / 1 (free) x internal 3.5" , 1 (total) / 0 (free) x external 3.5"
Slots
4 DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 , 3 (total) / 3 (free) x PCIe x1 , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 0 (free) x CPU
2 x USB 3.0 (2 in front) , 4 x USB 2.0 , 1 x headphones , 2 x microphone (1 front, 1 rear) , 1 x DVI-A , 1 x DVI-D , 1 x LAN , 1 x audio line-in
System password, power-on password, DriveLock
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Power supply
Power Provided
300 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
16.5 cm
37.3 cm
36.5 cm
9.6 kg
10 - 90% (non-condensing)
