HP 7320 AIO Intel® Core™ i3-2120 4GB, 500GB, 21.5", Windows 7 Professional 64-bit
Quicklinx: 87F2WS00 Mfr#: A2K11EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Core i3
  • IEEE 802.11n
The all-new HP TouchSmart Elite 7320 Business PC meets the most discerning style requirements with added performance, expandability, speed and power; it's everything your business needs in a sleek, modern design.
  • Capitalize innovative touch screen computing
    The full HD, 54,6 cm (21.5") diagonal widescreen display with multi-touch capabilities helps improve productivity. LED backlighting ensures images are consistently bright, while reducing power consumption.Use touch capabilities to streamline multistep processes and complete common tasks with greater accuracy and intuitiveness. Crop, resize and rearrange windows, images and document artifacts.Multiple users can interact with the bright, high-definition display, thanks to the wide viewing angle and panel movement from 0 degrees vertical to 30 degrees backwards.
  • Performance never looked so good
    The full HD, 54.6 cm (21.5-inch) diagonal widescreen LED backlit display adjusts easily for comfortable use. The sleek design enhances appearance in customer spaces and can be mounted on a wall, desk, or other surface via an integrated VESA mounting system. diagonal widescreen LED backlit display adjusts easily for comfortable use. The sleek design enhances appearance in customer spaces and can be mounted on a wall, desk, or other surface via an integrated VESA mounting system.The all-in-one PC design and integrated wireless LAN helps to reduce your computing footprint by integrating hardware and peripherals. Just unpack, place, plug in, and get to work.Perfect for customer facing locations, its slim profile, high-gloss finish and conveniently positioned ports and connectors, including an integrated 6-in-1 Media Card Reader, are the total package for your business.
  • Connect and collaborate with ease
    Connect and collaborate easily with the integrated desktop computer, 21.5" diagonal full HD1 WLED backlit monitor, 2.0 MP webcam and dual microphone array.Chat face-to-face and feel more connected to co-workers at the office, across town or on the other side of the globe using the built in webcam4 and array microphone. The webcam4 also captures and lets you instantly review photos and video clips.
  • Simply the latest technology
    Designed to give you the performance you need for today's process intensive and graphics rich applications. Intel 2nd Generation Core i3 and i5 processors provide top speeds and multiple cores for some of the most demanding applications you'll run.Two side SuperSpeed USB (3.0) ports deliver higher data transfer rates and improved power efficiency so you can take advantage of new technology and devices being developed.In today's data rich environment, businesses need all the storage they can get. The HP TouchSmart Elite 7320 offers SATA hard drives up to 2 TB and Slim Drives.
HP TouchSmart Elite 7320 - all-in-one - Core i3 2120 3.3 GHz - 4 GB - HDD 500 GB - LED 21.5" - TAA Compliant
Personal computer - all-in-one
Intel Core i3 (2nd Gen) 2120 / 3.3 GHz (Dual-Core)
Processor Socket
LGA1155 Socket
Processor Main Features
Hyper-Threading Technology
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
4 GB (installed) / 8 GB (max) - DDR3 SDRAM - non-ECC - PC3-10600
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 3Gb/s - 7200 rpm
Optical Storage
DVD SuperMulti
Card Reader
6 in 1
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9
Graphics Controller
Intel HD Graphics 2000 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
GigE, 802.11b/g/n
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Cyberlink PowerDVD, CyberLink PowerDirector, CyberLink Power2Go, PDF Complete Special Edition, CyberLink Label Print, HP Recovery Manager, HP Support Assistant, HP Power Assistant, Microsoft Office 2010 Starter, HP Vision Diagnostics, Norton Internet Security 2011 (60 days subscription), Windows Virtual PC, Mozilla Firefox for HP Virtual Solutions 2011, CyberLink PowerStarter, HP MyRoom, HP SimplePass PE 2011
55 cm x 20.5 cm x 43.8 cm
10.6 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers, display
Processor / Chipset
CPU
Clock Speed
3.3 GHz
Number of Cores
Dual-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1155 Socket
Chipset Type
Intel H61 Express
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 8 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
SO-DIMM 204-pin
Slots
2 (Total)
Unbuffered
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Card Reader
6 in 1 card reader
Supported Flash Memory Cards
Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, xD-Picture Card, SDHC Memory Card
Monitor
Monitor Type
LED
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Response Time
5 ms
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Integrated
Graphics Processor
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Integrated
Resolution (MP)
2 Megapixel
Input Device
Mouse, keyboard, touch-screen
Keyboard
Keyboard Name
HP Standard Value Keyboard
USB
Audio Input
Stereo microphone
Ethernet Controller
Realtek RTL8171EH
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
Slots
1 (total) / 0 (free) x CPU , 2 SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 0 (free) x PCIe Half Mini Card
4 x USB 2.0 , 2 x USB 3.0 , 1 x headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x remote control , 1 x microphone
Theft/Intrusion Protection
CSA, UL, FCC
TAA Compliant
Power adapter
Power Provided
180 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Software
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
55 cm
20.5 cm
43.8 cm
10.6 kg
5 °C
35 °C
15 - 80%
