HP 728 - 300ml Cyan Original DesignJet Ink Cartridge
Quicklinx: CGXGWS00 Mfr#: F9K17A
Type: Ink Cartridge
Technology: Inkjet
£165.46 ex VAT
£198.55 inc VAT
Facilitate communication and collaboration with quality prints from clear, easily readable drawings to colorful presentatins. To help reduce downtime and improve productivity-and protect your investment-Original HP inks are designed with your HP DesignJet printer or MFP as an optimized printing system. Choose from a range of cartridge sizes from 40 to 300 ml. Take advantage of free, convenient ink cartridge return and recycling.
Move projects forward and facilitate team collaboration with quality prints from clear, easily readable drawings to colorful, powerful presentations. With Original HP inks, you get crisp, clear, accurate lines and vivid color.
Save time with hassle-free printing. To get the consistent quality you need, look to Original HP inks designed with your printer or MFP as an optimized printing system. Fast-drying, smudge-resistant prints help you keep the pace.
It's your choice. A range of cartridge sizes from 40- to 300-ml HP ink cartridges are designed to fit your print volume. Large supplies can reduce intervention. Ink cartridge return and recycling is free and convenient.
HP 728 - cyan - original - DesignJet - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Printing Colour
Cyan
300 ml
Compatible with
DesignJet T730, T830
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Cyan
Included Qty
1-pack
300 ml
Compatible with
HP DesignJet T730, T830
Type: Ink Cartridge
Technology: Inkjet
Brand: HP
