HP 724pf Series 7 Pro 23.8" 1920x1080 5ms HDMI DisplayPort IPS LED Monitor
Quicklinx: HVB1WS00 Mfr#: 8X530AA#ABU
47 In Stock
£167.06 ex VAT
£200.47 inc VAT
Capture your vision better than you ever imagined with the HP Series 7 Pro 23.8" FHD Monitor. Trust what you see on screen with superb color accuracy right out of the box, a smooth 100 Hz refresh rate, and enhanced 1500:1 color contrast. Do it all with the ultra-thin 4-sided micro-edge frame and built-in ergonomics.
  • 100 Hz Refresh Rate
    Experience smooth, life-like videos and clear details.
  • More Contrast
    See more detail in color, shadow, and highlights thanks to the enhanced 1500:1 contrast ratio.
  • 99% sRGB & 85% Display P3 Color Gamuts
    Trust the colors you see on screen with all the shades and hues of 99% sRGB and 85% Display P3 color gamuts.
  • Accurate color out of the box
    Every HP Series 7 Pro Monitor undergoes strict factory color calibration to ensure that over 400 colors achieve a Delta E of less than 2, making any color difference virtually indistinguishable to the human eye for superb color accuracy.
  • IPS Panel Technology
    No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles.
  • More Ports. More Flexibility
    More ports means more capabilities. With an HDMI 1.4, 2 DisplayPort 1.2 in/out, and 4 additional USB-A ports, you can connect or charge multiple devices like a headset and webcam.
HP 724pf - Series 7 Pro - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1881923
Energy Class
Class E
Power Consumption (On mode)
18 W
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 100 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1500:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
100% BT.709, 99% sRGB, 85% DisplayP3
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Black, silver
53.84 cm x 19.5 cm x 48.93 cm
4.7 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Carbon Footprint
150 kg carbon emissions
VCCI, BSMI, GS, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, WW application, Ukraine EE, Ukraine CoC, Ukraine DOC
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
50 - 100 Hz
Horizontal Refresh Rate
30 - 111 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Flicker Free technology, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease, 4-sided micro-edge
Black, silver
53.84 cm x 19.5 cm x 48.93 cm - with stand
4.7 kg
DisplayPort (HDCP) , DisplayPort output (HDCP) , HDMI (HDCP) , USB (Type B) , 4 x USB 3.2 Gen 1 downstream (1 charging)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
Mount adapter
1 x DisplayPort cable , 1 x HDMI cable , 1 x USB type A to USB type B cable
Backlight Life
40,000 hours
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
36 Watt
Power Consumption (Max)
69 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 53.84 cm - depth: 19.5 cm - height: 48.93 cm - weight: 4.7 kg , Without stand - width: 53.84 cm - depth: 3.85 cm - height: 31.37 cm
Shipping Width
62.5 cm
Shipping Depth
37.3 cm
Shipping Height
14.2 cm
Shipping Weight
7 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
154
Logistics (kg CO2e)
2
Use (kg CO2e)
64
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
220
Limited warranty - 3 years
5 °C
35 °C
20 - 80% RH (non-condensing)
HVB1 HP DM V4+ VESA Sleeve In Stock £25.80
Brand: HP
