Capture your vision better than you ever imagined with the HP Series 7 Pro 23.8" FHD Monitor. Trust what you see on screen with superb color accuracy right out of the box, a smooth 100 Hz refresh rate, and enhanced 1500:1 color contrast. Do it all with the ultra-thin 4-sided micro-edge frame and built-in ergonomics.
100 Hz Refresh Rate
Experience smooth, life-like videos and clear details. -
More Contrast
See more detail in color, shadow, and highlights thanks to the enhanced 1500:1 contrast ratio. -
99% sRGB & 85% Display P3 Color Gamuts
Trust the colors you see on screen with all the shades and hues of 99% sRGB and 85% Display P3 color gamuts. -
Accurate color out of the box
Every HP Series 7 Pro Monitor undergoes strict factory color calibration to ensure that over 400 colors achieve a Delta E of less than 2, making any color difference virtually indistinguishable to the human eye for superb color accuracy. -
IPS Panel Technology
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles. -
More Ports. More Flexibility
More ports means more capabilities. With an HDMI 1.4, 2 DisplayPort 1.2 in/out, and 4 additional USB-A ports, you can connect or charge multiple devices like a headset and webcam.
- HP 724pf - Series 7 Pro - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1881923
- Energy Class
- Class E
- Power Consumption (On mode)
- 18 W
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1500:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% BT.709, 99% sRGB, 85% DisplayP3
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Black, silver
- 53.84 cm x 19.5 cm x 48.93 cm
- 4.7 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
- Carbon Footprint
- 150 kg carbon emissions
- VCCI, BSMI, GS, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, cTUVus, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, BIS, low halogen, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, WW application, Ukraine EE, Ukraine CoC, Ukraine DOC
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Pixel Per Inch
- 93
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 100 Hz
- Horizontal Refresh Rate
- 30 - 111 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Flicker Free technology, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease, 4-sided micro-edge
- Black, silver
- 53.84 cm x 19.5 cm x 48.93 cm - with stand
- 4.7 kg
- DisplayPort (HDCP) , DisplayPort output (HDCP) , HDMI (HDCP) , USB (Type B) , 4 x USB 3.2 Gen 1 downstream (1 charging)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Included Accessories
- Mount adapter
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable , 1 x USB type A to USB type B cable
- Backlight Life
- 40,000 hours
- Localisation
- Input Voltage
- 18 W
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 36 Watt
- Power Consumption (Max)
- 69 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 53.84 cm - depth: 19.5 cm - height: 48.93 cm - weight: 4.7 kg , Without stand - width: 53.84 cm - depth: 3.85 cm - height: 31.37 cm
- Shipping Width
- 62.5 cm
- Shipping Depth
- 37.3 cm
- Shipping Height
- 14.2 cm
- Shipping Weight
- 7 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Carbon Footprint
- Manufacturing (kg CO2e)
- 154
- Logistics (kg CO2e)
- 2
- Use (kg CO2e)
- 64
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 220
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% RH (non-condensing)
HP DM V4+ VESA Sleeve | In Stock | £25.80 |
