HP 715 - mouse - multi-device, rechargeable - Bluetooth 3.0, 2.4 GHz - black
Quicklinx: J577WS00 Mfr#: 6E6F0AA#ABB
Hurry, only 1 left in stock!
£49.60 ex VAT
£59.52 inc VAT
Find the freedom to work how you want with programmable buttons, up to 90-day battery life, and a compact ambidextrous design. Stay productive from anywhere, on any surface, and with many devices with track on glass sensor and multi-OS connectivity. Work better with the freedom you want and the flexibility you need, all in one mouse.
  • Customizable Buttons
    Tailor the 6 programmable buttons to fit you and your workstyle. Customize sensitivity and scroll speed, create app-specific shortcuts, and more, all through HP Accessory Center.
  • Up to 90 Days of Battery Life
    Power through days, weeks, and months without pause thanks to 90 days of battery life and rechargeable USB-C batteries.
  • Any Time, Any Place, Almost Any Surface
    Click into your work any place, any time, almost any surface...even glass.
  • Multi-OS Support
    Pair quickly and consistently to a Mac , Windows , Chrome, and more.
  • Connect to Multiple Devices
    Switch between up to 3 saved devices. 2.4GHz dongle or Bluetooth 5.3.
  • Thoughtful Product Packaging
    100% recyclable packaging and made with recyclable materials that meet requirements.
Mouse
Wireless, wired - Bluetooth 3.0, 2.4 GHz
5.71 cm x 3.62 cm x 10.21 cm
84 g
English / Europe
Wireless Receiver
USB wireless receiver
Buttons Qty
7
Movement Resolution
3000 dpi
Fast scrolling, silent click, Tilt Wheel technology, track-on-glass sensor, programmable buttons, battery indicator, 3 devices simultaneous connectivity
Windows 11, Google Chrome OS, Apple macOS 10.13 or later
1-year warranty
Mouse
Wireless Receiver
5.71 cm
3.62 cm
10.21 cm
84 g
Product Material
60% post-consumer recycled plastic
English / Europe
Input Device
Wireless, wired
Max Operating Distance
Up to 10 m
Buttons Qty
7
Movement Resolution
3000 dpi
1 x USB - 4 pin USB Type A
USB-C charging cable, USB dongle
CB, FCC, SDPPI, IMDA, BSMI, NCC, TRA, TRC, ICASA, ICES, KCC, VCCI, ANATEL, NOM, NBTC, ETL, WEEE, Green Dot, ETA, Triman
Lithium Ion
Run Time (Up To)
3 months
Software Included
HP Accessory Center
Shipping Width
15 cm
Shipping Depth
5.58 cm
Shipping Height
10.5 cm
Shipping Weight
260 g
Limited warranty - 1 year
