HP 711 3-pack 29-ml Yellow Ink Cartridge provides sharp, accurate results. See rich colour and sharp line accuracy in fast-drying, smudge-resistant prints. Original HP inks are designed and tested with your printer to provide consistent results.
Trial and error costs you time
See consistent quality-ultra-pure Original HP inks are designed with your printer for sharp, accurate results. -
Choose the size to fit your needs and your budget whether you print a little or a lot
Fit 29-ml color, 38-ml black cartridges to low print volume or 80-ml black, color 3-packs to high volume. -
Imagine the impact you can make with clear, easily readable drawings and colourful, powerful presentations
See sharp lines to 0.02 mm (0.0008 inch) minimum line width enabled by Original HP inks and your printer.
- HP 711 - 3-pack - yellow - original - DesignJet - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- HP Sub-brand
- DesignJet
- Printing Colour
- Yellow
- Capacity
- 29 ml
- Included Qty
- 3-pack
- Compatible with
- DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
- Dimensions (WxDxH) / Weight
- 180 g
- Shipping Width
- 11.9 cm
- Shipping Depth
- 12.6 cm
- Shipping Height
- 4.6 cm
- Shipping Weight
- 200 g
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- HP Sub-brand
- DesignJet
- Yellow
- Included Qty
- 3-pack
- Capacity
- 29 ml
- Compatible with
- HP DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
