HP 711 3-Pack 29-ml Cyan/Magenta/Yellow Ink Cartridges
Quicklinx: CNV8WS00 Mfr#: P2V32A
It's easy to get consistent, sharp, accurate results with Original HP inks, designed together with your printer as an optimized printing system.
Trial and error costs you time. To get the consistent quality you need, look to Original HP supplies designed with your printer as an optimized printing system to provide accurate lines, sharp detail, and rich color quality.
See consistent quality—ultra-pure Original HP inks are designed with your printer for sharp, accurate results.
Choose the size to fit your needs and your budget whether you print a little or a lot. Color cartridge 3-packs keep you working, not running to the store. Intelligence built into the cartridge and printer alerts you when it's time for a replacement.
Fit 29-ml color, 38-ml black cartridges to low print volume or 80-ml black, color 3-packs to high volume.
Imagine the impact you can make with clear, easily readable drawings and colorful, powerful presentations. Original HP inks deliver a unique combination of quality and resilience—see sharp lines in fast-drying, smudge-resistant prints.
See sharp lines to 0.02 mm (0.0008 inch) minimum line width enabled by Original HP inks and your printer.
  • More time, less hassle-reliable HP performance
    See consistent quality-ultra-pure Original HP inks are designed with your printer for sharp, accurate results.
  • Tailor-fit to your needs and easy to use
  • Accentuate the detail, see pinpoint line accuracy
HP 711 - 3-pack - yellow, cyan, magenta - original - DesignJet - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Printing Colour
Yellow, cyan, magenta
29 ml
Included Qty
3-pack
Compatible with
DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
Shipping Width
11.9 cm
Shipping Depth
4.62 cm
Shipping Height
12.6 cm
Shipping Weight
180 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Included Qty
3-pack
29 ml
Consumables Included
1 x ink cartridge (cyan) - 29 ml , 1 x ink cartridge (magenta) - 29 ml , 1 x ink cartridge (yellow) - 29 ml
Compatible with
HP DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
