HP 711 29-ml Magenta Ink Cartridge
Quicklinx: 8VRTWS00 Mfr#: CZ131A
Type: Ink Cartridge
Technology: Ink-Jet
More than 50 In Stock
£27.81 ex VAT
£33.37 inc VAT
HP 711 29-ml Magenta Ink Cartridge provides consistent, accurate results. See rich colour and sharp line accuracy in fast-drying, smudge-resistant prints. Original HP inks are designed and tested with your printer to provide consistent results.
  • Trial and error costs you time
    See consistent quality-ultra-pure Original HP inks are designed with your printer for sharp, accurate results.
  • Choose the size to fit your needs and your budget whether you print a little or a lot
    Fit 29-ml color, 38-ml black cartridges to low print volume or 80-ml black, color 3-packs to high volume.
  • Imagine the impact you can make with clear, easily readable drawings and colourful, powerful presentations
    See sharp lines to 0.02 mm (0.0008 inch) minimum line width enabled by Original HP inks and your printer.
HP 711 - magenta - original - DesignJet - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Printing Colour
Magenta
29 ml
Compatible with
DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
Dimensions (WxDxH) / Weight
60 g
Shipping Width
11.4 cm
Shipping Depth
12.6 cm
Shipping Height
2.5 cm
Shipping Weight
80 g
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Magenta
Included Qty
1-pack
29 ml
Compatible with
HP DesignJet T100, T120, T120 ePrinter, T125, T130, T520, T520 ePrinter, T525, T530
Type: Ink Cartridge
Technology: Ink-Jet
Brand: HP
