Easy to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Carry and store with your device
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
- HP USB-C LC - power adapter - 65 Watt
- Power adapter - external
- Localisation
- English / Europe
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Designed For
- Pro c640 G2 Chromebook; ProBook 635 Aero G7 Notebook
- Localisation
- English / Europe
- Input Voltage
- AC
- Power Capacity
- 65 Watt
- Designed For
- HP Pro c640 G2 Chromebook , HP ProBook 635 Aero G7 Notebook
