Power and charge your notebook or tablet from its USB-C port with the HP 65W USB-C Power Adapter.
Simple to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Easy to carry and store
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it. -
World-class support
Rest easy with a one-year limited warranty.
- HP - power adapter - 65 Watt
- Power adapter - external
- 220 g
- Localisation
- English / United Kingdom
- Input Voltage
- AC
- Output Voltage
- 5 / 9 / 10 / 12 / 15 / 20 V
- Power Capacity
- 65 Watt
- Input Connectors
- 24 pin USB-C
- 7.4 cm x 7.4 cm x 2.85 cm
- 1-year warranty
- Localisation
- Input Voltage
- AC
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- 24 pin USB-C
- Output Voltage
- Max Electric Current
- 8 A
- Power Capacity
- 65 Watt
- Efficiency
- 81.5% min at AC 115/230 V (5V/3A), 86.7% min at AC 115/230 V (9V/3A), 88% min at AC 115/230 V (10V/5A), 88% min at AC 115/230 V (12V/5A), 89% min at AC 115/230 V (15V/4.33A), 89% min at AC 115/230 V (20V/3.25A)
- MTBF
- 100,000 hours
- FCC Class B certified, EN 60950, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, cULus, LVD, NOM-1-NYCE
- Limited warranty - 1 year
- 0 °C
- 35 °C
- 5 - 95%
- 7.4 cm
- 7.4 cm
- 2.85 cm
- 220 g
