HP 65W SMART AC ADAPTOR
HP 65W Smart AC Adapter
Quicklinx: 6P6LWS00 Mfr#: ED494AA#ABU
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
  • Easy to use
    Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Power up wherever you work
    Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
  • World-class support
    Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
HP Smart - power adapter - 65 Watt
Power adapter - external
280 g
English / United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
18.5 V
Power Capacity
65 Watt
10.6 cm x 4.7 cm x 2.8 cm
1-year warranty
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
MTBF
200,000 hours
FCC Class B certified, CISPR 22 Class B, cUL, EN 60950, IEC950, NOM, UL 1950, EN55022 Class B
Limited warranty - replacement - 1 year
20 - 80%
10.6 cm
4.7 cm
2.8 cm
280 g
