Brand
HP 65W Smart AC Adapter
Quicklinx: C872WS00 Mfr#: H6Y89AA#ABU
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
  • Easy to use
    Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Power up wherever you work
    Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
  • World-class support
    Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
HP Smart AC Adapter - power adapter - 65 Watt
Power adapter - external
280 g
English / United Kingdom
Output Voltage
18.5 V
Power Capacity
65 Watt
Output connectors
1 x power DC jack 4.5 mm
4.5mm to 7.4mm power DC dongle
10.6 cm x 4.7 cm x 2.8 cm
EliteBook 830 G6, 84XX, 85XX, 87XX; ProBook 450 G7, 455 G8, 455r G6, 45X G3, 45X G4, 45X G5, 45X G9, 470 G4, 470 G5, 635, 640 G5, 64X G1, 64X G2, 64X G3, 64X G4, 650 G5, 65X G1, 65X G2, 65X G3; ZBook 14, 14 G2, 14u G4, 14u G5, 14u G6, 15u G2, 15u G3, 15u G4, 15u G6; ZBook Firefly 14 G8, 15 G8
Input Voltage Range
AC 90 - 265 V
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
Power cable , Power connector adaptor
Over voltage protection
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
5 °C
35 °C
10.6 cm
4.7 cm
2.8 cm
280 g
Shipping Weight
0.6 kg
HP 215 G1 Notebook, 240 G1 Notebook, 240 G2 Notebook, 245 G1 Notebook, 245 G2 Notebook, 245 G7 Notebook, 245 G8 Notebook, 248 G1 Notebook, 250 G1 Notebook, 250 G2 Notebook, 250 G3 Notebook, 250 G5 Notebook, 255 G1 Notebook, 255 G2 Notebook, 255 G5 Notebook, 256 G8 Notebook, 340 G1 Notebook, 340 G2 Notebook, 340 G5 Notebook, 340 G7 Notebook, 340S G7 Notebook, 348 G5 Notebook, 470 G7 Notebook, 470 G8 Notebook , HP EliteBook 830 G6, 8440p Notebook, 8440w Mobile Workstation, 8460p Notebook, 8460w Mobile Workstation, 8470p Notebook, 8470w Mobile Workstation, 8530p Notebook, 8540p Notebook, 8560p Notebook, 8570p Notebook, 8730p Notebook, 8740p Notebook , HP ProBook 11 G1 Notebook, 430 G1 Notebook, 430 G2 Notebook, 430 G3 Notebook, 430 G4 Notebook, 430 G5 Notebook, 430 G7 Notebook, 440 G3 Notebook, 440 G4 Notebook, 440 G5 Notebook, 440 G7 Education Edition Notebook, 440 G7 Notebook, 440 G9 Notebook, 445 G8 Notebook, 445 G9 Notebook, 445r G6 Notebook, 450 G0 Notebook, 450 G1 Notebook, 450 G2 Notebook, 450 G3 Notebook, 450 G4 Notebook, 450 G5 Notebook, 450 G7 Notebook, 450 G9 Notebook, 455 G1 Notebook, 455 G3 Notebook, 455 G4 Notebook, 455 G5 Notebook, 455 G8 Notebook, 455 G9 Notebook, 455r G6 Notebook, 470 G0 Notebook, 470 G1 Notebook, 470 G2 Notebook, 470 G3 Notebook, 470 G4 Notebook, 470 G5 Notebook, 635 Aero G8 Notebook, 640 G1 Notebook, 640 G2 Notebook, 640 G3 Notebook, 640 G4 Notebook, 640 G5 Notebook, 645 G1 Notebook, 645 G2 Notebook, 645 G3 Notebook, 645 G4 Notebook, 650 G1 Notebook, 650 G2 Notebook, 650 G3 Notebook, 650 G5 Notebook, 655 G1 Notebook, 655 G2 Notebook, 655 G3 Notebook, Fortis 14 G9 Notebook , HP ZBook 14 G2 Mobile Workstation, 14 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G6 Mobile Workstation , HP ZBook Firefly 14 G8 Mobile Workstation, 15 G8 Mobile Workstation
