HP 65W Smart AC Adapter
Quicklinx: C872WS00 Mfr#: H6Y89AA#ABU
Device Type: Laptop
Type: Power Adapter
Device Screen Size: [N/A]
Colour: Black
Hurry, only 1 left in stock!
£17.30 ex VAT
£20.76 inc VAT
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
  • Easy to use
    Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Power up wherever you work
    Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
  • World-class support
    Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
HP Smart AC Adapter - power adapter - 65 Watt
Power adapter - external
280 g
English / United Kingdom
Output Voltage
18.5 V
Power Capacity
65 Watt
Output connectors
1 x power DC jack 4.5 mm
4.5mm to 7.4mm power DC dongle
10.6 cm x 4.7 cm x 2.8 cm
Input Voltage Range
AC 90 - 265 V
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
Power cable , Power connector adaptor
Over voltage protection
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
5 °C
35 °C
10.6 cm
4.7 cm
2.8 cm
280 g
Shipping Weight
0.6 kg
Device Type: Laptop
Type: Power Adapter
Colour: Black
Brand: HP
