Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
                Easy to useControl the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
                Power up wherever you workProtect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
                World-class supportEliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
- HP Smart AC Adapter - power adapter - 65 Watt
- Power adapter - external
- 280 g
- Localisation
- Europe
- Output Voltage
- 18.5 V
- Power Capacity
- 65 Watt
- Output connectors
- 1 x power DC jack 4.5 mm
- Included Accessories
- 4.5mm to 7.4mm power DC dongle
- 10.6 cm x 4.7 cm x 2.8 cm
- Localisation
- Europe
- Input Voltage Range
- AC 90 - 265 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- 18.5 V
- Power Capacity
- 65 Watt
- Cables Included
- Power cable
- Over voltage protection
- CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
- 5 °C
- 35 °C
- 10.6 cm
- 4.7 cm
- 2.8 cm
- 280 g
- Shipping Weight
- 0.6 kg
