HP 65W AC Adapter NPFC Smart 3P 7.4MM
Quicklinx: GDXHWS00 Mfr#: L40094-001
Hurry, only 3 left in stock!
£21.09 ex VAT
£25.30 inc VAT
Conserve battery life, be productive, and get uninterrupted power with the HP 65 W Smart AC adapter, which detects and regulates the correct electrical current for your device.
  • Easy-to-use
    Plug one end of the adapter into your HP device and the other end into a standard outlet.
  • Power up wherever you work
    Leave a handy spare at home or take the compact adapter with you.
HP Smart - power adapter - 65 Watt
Power adapter - no Power Factor Correction (PFC) - external
Input Voltage
AC
Power Capacity
65 Watt
HP 200 G4, 205 G3, 205 G4, 2510p, 260 G4, 2710p; EliteDesk 705 G5 (65 Watt), 800 G5 (65 Watt); ProDesk 400 G5 (65 Watt), 400 G6 (65 Watt), 600 G5 (65 Watt), 600 G6 (65 Watt)
Input Voltage
AC
Power Capacity
65 Watt
HP 200 G4, 205 G3, 205 G4, 260 G4 , HP EliteDesk 705 G5 (65 Watt), 800 G5 (65 Watt) , HP ProDesk 400 G5 (65 Watt), 400 G6 (65 Watt), 600 G5 (65 Watt), 600 G6 (65 Watt) , HP Compaq 2510p, 2710p
Brand: HP
