HP 650 G2 I36100U 4GB/500GB
Quicklinx: CH2XWS00 Mfr#: Z2V16ET#ABU
  • Core i3
  • IEEE 802.11n
  • DVD-ROM
Equip your workforce with HP's configurable and cost-effective notebook PC. Confidently deploy the HP ProBook 650 which combines support for advanced features that provide long-term stability with excellent security for today's business. Ideal for professionals in corporate settings or small to medium businesses, wanting an affordable combination of innovation, essential security and multimedia capabilities.
Easy integration
Help get the most out of existing IT investments with the HP ProBook 650. Take advantage of legacy features like a standard VGA port, an RJ-45 connection, an optional optical drive, and a native serial port.
Powerful processing and drive options
Select from powerful 6th Gen Intel® Core™ processors and integrated Intel® HD UMA graphics along with other configurable options that let businesses configure the right ProBook 650 for each user’s needs.
Professional-grade
Create a full featured experience with powerful processors, robust DDR4 memory, and professional-grade peripheral devices like HP Pro Displays and an HP Ultraslim dock.
Executive-class collaboration
Interact naturally with your PC using an optional FHD Touch screen and Cortana on Windows 10 Pro. Enjoy impressive collaboration tools like Skype for Business, HP Noise Reduction Software, and a 720p webcam for collaboration on the go.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 650 with AMD Radeon discrete graphics 2GB-GDDR5.
  • Customized protection
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
  • Cut out the chatter
    Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
  • Give your speakers a boost
    Help make good speakers sound great with the HP Clear Sound Amp.
  • Tested to go the distance
    Stand up to the workload with a ProBook that passed MIL-STD 810G testing.
  • Protect against minor spills
    Help protect your ProBook with a spill-resistant HP Premium Keyboard with backlit options available.
HP ProBook 650 G2 Notebook - 15.6" - Intel Core i3 - 6100U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i3 (6th Gen) - 6100U / 2.3 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD
Display
15.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Input Device
Pointing stick
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 9.75 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
37.8 cm x 25.7 cm x 2.74 cm
2.31 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i3 (6th Gen) 6100U / 2.3 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD-ROM
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
High Definition Audio, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
Run Time
Up to 9.75 hours
AC Adapter
Output
45 Watt
Connections & Expansion
Interfaces Details
USB-C , USB 3.0 , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA , Serial , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Case Material
Polycarbonate ABS
Dockable
Security
HP 3D DriveGuard, soft-touch surface, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS, WEEE, Common Criteria EAL4+
Localization
HP Smart Buy
2.31 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
