HP 642A Yellow Original LaserJet Toner Cartridge
Quicklinx: 49VNWS00 Mfr#: CB402A
Type: Toner Cartridge
Technology: Laser
Hurry, only 3 left in stock!
£228.67 ex VAT
£274.40 inc VAT
HP 642 LaserJet Printing Supplies are designed for fast, easy, reliable results. HP ColorSphere toner produces a dynamic range of bright, brilliant colour. HP Smart printing technology optimises print quality and reliability.
  • High-technology matches the brilliance of your ideas with HP ColorSphere toner
    With a unique toner particle design, HP ColorSphere toner accomplishes uniform, high gloss. Gloss enables a dynamic range of bright, brilliant colors. The result is bold graphics and realistic images that enable photo-quality business printing. HP ColorSphere toner produces a fine range of colors. To ensure extreme precision in the printing process, HP's color toner uses advanced toner formulation technology. Each toner particle that's produced conforms to an extremely consistent size and shape, allowing the particles to be placed on the page with the precision that's needed to produce a wide range of colors with even the most subtle differences of shade. With this precision, you get high-impact photo-quality business printing.
  • Quick, easy, more productive, HP ColorSphere toner enables fast, high-quality printing
    Documents come off the printer quickly without sacrificing quality. HP ColorSphere toner particles are scientifically developed around a perfectly sized wax core designed to work with HP's instant-on fusing technology for faster image processing with optimum results. HP Smart Printing technology makes HP printing supplies easy to replace and reorder. How does it work HP supplies and your printers exchange information to provide a snapshot of supplies across printers, providing timely status and alerts. HP Color LaserJet toner cartridges comprise up to 70% of your printer's imaging system. To make the system easy to use and to ensure legendary HP reliability, the all-in-one cartridge is designed for simple operation, incorporating the toner and imaging drum in one supply. HP ColorSphere toner is formulated to enhance this design, to make this critical component even more reliable.
  • HP Smart technology is finely tuned to the unique properties of HP ColorSphere toner, enabling the cartridges and the printer to trigger adjustments that optimize print quality and reliability
    For consistency over the cartridge's life, HP Smart technology in HP supplies and the printer relies on the unique properties of HP ColorSphere toner. As the system triggers adjustments to the electro photographic voltages inside the toner cartridge, a precise mix of patented additives - fine-tuned for quality results under diverse environmental conditions - ensures consistency. HP supplies and the printer work together to ensure the quality of each print, saving time and providing real value. To keep your productivity high, HP designs in reliability to maximize quality and uptime.
HP 642A - yellow - original - LaserJet - toner cartridge (CB402A)
Toner cartridge
Printing Technology
Laser
HP Sub-brand
LaserJet
Printing Colour
Yellow
Yield
Up to 7500 pages at 5% coverage
Compatible with
Color LaserJet CP4005dn, CP4005n
Dimensions (WxDxH) / Weight
1.7 kg
Shipping Width
40 cm
Shipping Depth
14.8 cm
Shipping Height
26.8 cm
Shipping Weight
2.2 kg
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
HP Sub-brand
LaserJet
Yellow
Included Qty
1-pack
Yield
Compatible with
HP Color LaserJet CP4005dn, CP4005n
Technology: Laser
Brand: HP
Price Range Ex VAT: 150 - 300
