Stylish performance. Watch, present, video conference, and multitask on this durable, stylish notebook. This versatile and secure HP 635 boasts a 39,6 cm (15.6") diagonal HD monitor to make an impression in and out of the office.
Equipped to get the job done
Optimized for Windows 7 Professional , you gain strong processor capabilities, wireless functionality and a 39,6 cm (15.6") diagonal HD display. -
Stylish design
This notebook has a sophisticated ID design with smooth matte surface in an understated pewter color for a clean professional look. -
System recovery
Your data is important. With HP Recovery Manager preinstalled in image, you can quickly recover and get back to work when your operating system is corrupted. -
Easily stay productive
With optional Wi-Fi CERTIFIED WLAN you can send and receive e-mails or access the Internet – at work, at home and at your favorite hotspots . -
Crystal clear collaboration
Reduce your communication costs and improve your productivity with the webcam for video conferencing, digital microphones and Altec Lansing speaker for better sound quality. -
The best of both worlds
With Switchable Graphics (on select models) , you can get high performance from discrete graphics or the long battery life of integrated graphics in the same notebook.
- HP 635 - 15.6" - E-450 - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit
- Processor
- AMD E-450 1.6 GHz / 1 MB Cache
- Memory
- 4 GB DDR3
- Storage
- 500 GB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon HD 6320
- Networking
- 802.11b/g/n, Bluetooth 2.1 EDR, Bluetooth 3.0 HS, 10/100 Ethernet
- Battery
- 6-cell - up to 5 hours
- 37.6 cm x 24.7 cm x 3.6 cm
- 2.5 kg
- Microsoft Office Preloaded
- Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
- Localisation
- Language: English / region: United States
- Limited warranty - 1 year - pick-up and return
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition
Processor / Chipset
- CPU
- AMD E-450 1.6 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- RAM
- 4 GB
- Max RAM Supported
- 8 GB
- Technology
- DDR3 SDRAM
- Speed
- 1333 MHz / PC3-10600
- Rated Speed
- 1333 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
Audio & Video
- Graphics Processor
- Sound
- Stereo speakers, microphone
- Codec
- Realtek ALC270A-GR
- High Definition Audio
- Audio Features
- Output: Altec Lansing speakers
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Network Interface
- 10/100 Ethernet
- Remote Management Protocol
- SNMP
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED
- Technology
- 6-cell Lithium Ion
- Capacity
- 47 Wh
- Run Time
- Up to 5 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 18.5 V
Connections & Expansion
- VGA , HDMI , Microphone input , Headphone output , LAN , 3 x USB 2.0
- Memory Card Reader
- Yes (SD Card, MultiMediaCard)
Software
- Software Included
- HP Recovery Manager, Norton Internet Security 2011 (60 days trial)
- Security lock slot (cable lock sold separately), system password
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, C-Tick, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, ICES
- Localization
- 2.5 kg
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
