Create graphic-rich presentations on the HP Compaq Pro 6305 Microtower and keep everyday productivity flowing with the latest AMD processor technology. Grow and customize with multiple expansion options and support multi-display setups for expanded screen real-estate. Protect your data with enterprise-class security and simplify manageability with a strong lifecycle and reliable warranty.
Your budget-friendly performance boost
Deliver rich, effective presentations with stunning media-enhanced content on the affordably priced PC. As it is loaded with a powerful processor, you'll benefit from great productivity gain. -
Security and reliability, right out of the box
Extend your IT investment with long, predictable lifecycles of long time. With this PC, you're protected at every layer.
- HP Compaq 6305 Pro - micro tower - A4 6300B 3.7 GHz - 4 GB - HDD 500 GB - TAA Compliant
- Personal computer - micro tower - system password, power-on password, serial port I/O control, USB port control, DriveLock
- Localisation
- Processor
- AMD A4 6300B / 3.7 GHz (, up to 3.9 GHz, (Dual-Core)
- Cache Memory
- 1 MB L2 Cache
- Cache Per Processor
- 1 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- AMD Radeon HD 8370D
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- Software Included
- Adobe Flash Player, HP Help and Support, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, Bing Toolbar, PDF Complete Corporate Edition, WinZip Basic, HP Marketplace, HP Wallpaper, HP Setup 9.0, SRS Premium Sound, HP Client Security, HP EUDI Support Environment
- 17.7 cm x 43.1 cm x 37.7 cm
- 9.3 kg
- Manufacturer Selling Program
- HP Smart Buy
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Micro tower
- Built-in Devices
- Speaker, solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- AMD A4 6300B
- Clock Speed
- 3.7 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- AMD A75
Cache Memory
- Installed Size
- L2 Cache - 1 MB
- 1 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Keyboard
- Interface
- USB
Mouse
- Technology
- Optical
- Interface
- USB
- Integrated
- Interface (Bus) Type
- PCI Express
- Ethernet Controller
- Broadcom BCM5761
- Data Link Protocol
- Remote Management Protocol
- DMI 2.0, ASF 2.0
- Wake on LAN (WoL), ACPI support, PXE support
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Bays
- 2 (total) / 1 (free) x external 5.25" , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x PCI - full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 - full-height (x4 mode)
- 6 x USB 3.0 (2 front, 4 rear) , 6 x USB 2.0 (4 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- System password, power-on password, serial port I/O control, USB port control, DriveLock
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- HP Smart Buy
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 320 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro 64-bit) + Windows 8 Pro 64-bit Licence
- OS Certified
- SUSE Linux Enterprise Desktop 11
- Software
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 17.7 cm
- 43.1 cm
- 37.7 cm
- 9.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
