HP 6200 Pro MT Intel® Core™ i5-2400, 4GB, 500GB, DVD+/-RW, Windows 7 Professional 64-bit
HP Compaq 6200 Pro Microtower-PC (ENERGY STAR)
Quicklinx: 7H5LWS00 Mfr#: XY107ET#ABU
  • Core i5
  • Red Hat Enterprise Linux
  • Microsoft Windows 7 Professional 64-bit Edition
The HP Compaq 6200 Pro includes proven PC modules and components designed to rigorous business PC standards. Delivered in two familiar form factors, the 6200 Pro Series will satisfy most everyday business computing requirements.
  • Advancements in technology
    Designed for maximum performance throughout its life, the HP Compaq 6200 Pro offers the right blend of features required for businesses like yours. Enhancements to SDRAM system memory and Serial ATA drive technology, and the Intel business PC technologies support a broad range of functions to help you get the job done.
  • Built for business
    This PC is designed to help facilitate a more stable and manageable environment with features such as the Intel Stable Image Platform Program that allows for more efficient planning, deployment, and transition of PCs. Easily optimize the PC's power settings with HP's exclusive Power Assistant application. A control panel helps you maintain control of the PCs energy usage.
  • Stability and manageability
    HP BIOS helps businesses to maintain control over their PC fleet. You'll get technology to help integrate your PC into your business, track it and help control thermal and power management. HP software also helps provide diagnostic and service information making upgrades easier and keeping lifecycle tracking at your fingertips.
HP Compaq 6200 Pro - micro tower - Core i5 2400 3.1 GHz - 4 GB - HDD 500 GB
Personal computer - micro tower - system password, power-on password, parallel port I/O control, serial port I/O control, USB port control, DriveLock
Intel Core i5 (2nd Gen) 2400 / 3.1 GHz (, up to 3.4 GHz, (Quad-Core)
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-10600
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - 7200 rpm
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 2000 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE
OS Provided
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Software Included
Windows 7 Professional 64-bit recovery DVD, HP Vision Diagnostics, Norton Internet Security 2011 (60 days subscription), HP Software Management Agent, HP Insight Diagnostics, PDF Complete Corporate Edition
17.7 cm x 43.1 cm x 37.7 cm
9.3 kg
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Micro tower
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.1 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
64-bit Computing
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q65 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
1333 MHz
Rated Memory Speed
1333 MHz
Memory Specification Compliance
PC3-10600
DIMM 240-pin
Slots
4 (Total)
Unbuffered
Hard Drive
HDD
1 x 500 GB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ)
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Read Speed
40x (CD) / 16x (DVD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD-R DL) / 12x (DVD+R DL)
CD / DVD Rewrite Speed
32x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 12x (DVD-RAM)
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Integrated
Ethernet Controller
Intel 82579LM
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 1 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
4 DIMM 240-pin , 1 (total) / 1 (free) x PCI - full-height , 2 (total) / 2 (free) x PCIe x1 - full-height , 1 (total) / 1 (free) x PCIe x16 - full-height , 1 (total) / 0 (free) x CPU
10 x USB 2.0 (4 front, 6 rear) , 1 x audio line-in/microphone , 1 x audio line-out , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x VGA , 1 x DisplayPort
System password, power-on password, parallel port I/O control, serial port I/O control, USB port control, DriveLock
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
ACPI, RoHS, WEEE
HP Smart Buy
Power supply
Power Provided
320 Watt
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
17.7 cm
43.1 cm
37.7 cm
9.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
7H5L HPE DisplayPort DVI-D Adapter In Stock £11.55
